Everything posted by Eshaw08
Where to buy forged internals
Eshaw08 replied to Eshaw08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXor what can of boost can i run with out forged internals
Yea im bout to rebuild a motor as a spare i wan to rebuild it for turbo and i want to run 12-16lbs of boost. Where can i find the parts it is a 1996 legacy 2.2 ej22
96 legacy loud popping when shifting
Eshaw08 replied to Eshaw08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is fixed. I was off this weekend so i got up under it and i found 2 bolts on the crossmember that i left loose and tightened them up and no more noise.
Eshaw08 replied to Eshaw08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts a pop it does it about five times it does it when in gear with whenfloored it does it during hard shifting and it does not go away with shift up. Like when I down shift. And let off the clutch. In goes pop pop pop pop. And it does when accel?erating hard ill check the tranny mount when I get home
Eshaw08 replied to Eshaw08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXheres the problem it only does it while its driving the clutch doesent have to be in use if u jerk the car with the gas it will do it
Eshaw08 replied to Eshaw08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell its not a clutch issue with the popping cause i found out that its not only undershifting power when it does it but also if I press and then release the gas really fast. Usually makes the noise when im making the car jerk. Its not believed to be a motor mount or trans mount and dosent do it while turning. I have replaced all of the half shafts and the u joints on the drive shaft are good. Im not worried about the clutch shutter because I may be using the wrong vocab. It might be the way i drive a stick. But before the trans was pulled it didnt make the noise. And it does in gear and does not do it while the car is not running. also it has a issue with it running very rich. But it is not throwing a code and i no it is because of the exhaust smell sorry if it sound all clustered together and the clutch is new
I just reinstaled my 5 speed trans in my 96 leagcy it had a bad oil seal. now in order to replace the seal i had to tear the trans apart. every thing went back together perfect. During the process we lost a release bearing clip and had to make a new one. Well when i shift it pushing and releasing the clutch i get a poping and clutch chatter. and when i shift hard its extreamly loud. It wasent doing it before i put it back in and its not a mount. plz help if i have to ill pull the trans back out and take it apart anand rebuild it up again
