subarurx
Posts posted by subarurx
yep, that's the only measurement of speed there is
that is what we have, a std EA box, with wrx ra gear kit + diffs , 12kg viscous centre diff (4.11) and a rear LSD from an impreza it is worth the effort (not that I built it). the car has only a 175-180 top speed, but it gets there very quickly. 4th tops out at about 115-120...and 5th pulls strongly to 175-180
photo is taken at about 7am on a very cold morning in mid winter, outside a hotel in Rotorua. the car had ben outside all night, and I have only jsut started it up to warm it up before we left at 8ish. I think it was about -1 degrees c so it was a little cold...
sure was fun, and most of the stages ranged betw. 17 - 37km long...
hi there, here's the stats for my car.
Front
- 45mm Bilsteins (custom made) with adj platforms
- Not sure of spring rate, but have had them dyno'd so the struts are valved correctly.
- Custom made bottom arms, with rose joints on the inner side of the arm to adjust camber, to remove the crap camber they have. If you look at some of the images on my site, you will see it has good camber on the front.
Rear
- Koni with adj platforms
- Not sure of spring rate. resonably soft, as if yu go too hard the Leone floggs the rump roast, and understeers like a tractor on slicks
Setup
As you will see in the photo, I run the car with the front 1.5cm - 2cm higher than the rear, this stops the rear becoming light underbraking,
internal:
kevlar seats + 6 point belts
momo wheel
brantz tripmeter
6 point cage with side intrusion bars
sparco intercom
under the hood:
forged pistons and some special rings (forget there name)
uprated oil pressure/pump
legacy radiator
FMIC
14psi boost on std turbo
adjustable boost
dump valve
strut brace
drivetrain:
centre bonded double diaphram clutch (forget the exact details)
wrx ra gear box with custom mounts
shortened drive shaft
12kg centre viscius diff
4.11 ratio front/rear diffs
misc:
total stripped out shell, all door panels replaces with light polycarb sheeting, all sound deadening has been taken out/ tank guards / full underbody potections + hell flaps over the rear suspension
rims:
5 x 13" standard steel rims
15 x 13" alloys - http://www.ultimatesubaru.org/80s/wheels2/wagalloy.jpg
8 x 14" standard steel rims
4 x 14" aftermarket alloys - http://www.ultimatesubaru.org/80s/wheels2/new-alloy.jpg
4 x 14" Enkei WRC alloys - http://www.ultimatesubaru.org/80s/w...ts_14_alloy.jpg
check out the car more at the site on my signature. we do the Top Half rally series in New Zealand. Any other q's, please email me on simon@terabyte.co.nz
Hey all
this is my car the morning before the start of Rally Rotorua...looking nice and clean...
this is what happened during the event....
We finished Rotorua, what an event, we had a bit of an eventful time, here's our story...
FRIDAY
SS1, blew fifth gear off the line...so only had a top speed of 120km/hr for the rest of the event, instead of 180km/hr ..talk about boring and an easy way to lose truckloads of time on long straights and fast corners.
SS2, hit a huge rock, damaged the manifold, lost turbo boost...an 1800 with no turbo = a gutless wonder. Still, least we did the stage.
SS3, no boost, well only about 4psi, compared to the usual 15psi, decided to attack the downhill twisty last 6km of the stage, arrived at time control with brakes on fire...the farmer spectating at the finish control looked at them and was quite amazed.
SS4, Motu One..wow what a stage, so fast in places next to the river, then uphill and really twisty. We had no boost, a loud noisy exhaust, but thankfully no long straights...but on the uphills we about as fast as Marion Jones runs the 100m now...not so fast.
SS5, Motu Two..wow, another fantastic stage, manifold has nearly fallen off, no boost whatsoever, and holed the header tank to the radiator about 3/4 of the way through, lucky it is higher than the radiator, and the car didn't loose to much fluid, nor overheat...
SS6, Whakarau, clocked out of service 14min late, incurred 2min20sec in lateness trying to weld the manifold, got 3psi boost, and radiator header tank still leaking a bit, but fantastic stage, and again attacked the downhills..thankfully the brakes were good. This was a terrific stage, such flowing roads that were smooth and fast, it was a drivers road, one that would have been the highlight of the rally.
SS7, Rakaroa, another grouse stage, header tank leaked, but managed not to overheat the car, passed Dave Bone in the Mini on this stage, well only just, the mini had more go up the hill than the mighty boost-less leone...so again had a real go at the downhills to try and make a up a bit of time. Again had slighty smoky brakes at the end of the stage.
End of day one, we were 13th o/a in clubmans, 4th o/a in class, not a bad result consider the problems. At the 45min service before we headed back on the 200km tour to Rotorua from Matawai, we managed to fix some of the leaky exhaust.
SATURDAY
SS8, had the manifold 3/4 welded in the mornings service, got 8psi boost, and some semi-respectable stage times, although this stage was really fast, and needed 5th gear, so we got caught by the Impreza behind us on the road...there goes 13th, back to 14th o/a.
SS9, no real problems, just the same, not much boost and no 5th gear
SS10, 1km in, a 4Left, I threw the car off the road at 110km/hr (well actually the gear box decided to destroy itself, and locked up the right front wheel), bent the control arm like a banana and pushed the floor up where the bracket is, and left the car high and dry, lost 22min waiting for the recovery car to pull us out, then clocked in 14min late at the next time control, as I could only drive through the stage, the wheel was rubbing so badly on the mudflap and guard. Glad we only drove, as it was incredibly rough.
SS11, drove through the stage... still didn't set the slowest time...ha ha.
We finished 15th o/a, 4th in class...could have got a top 10 if all was working ok...but hey that is rallying...
hey EA82
I am in auckland and do the top half series, but will be in nelson as I manage a team in the NZRC, so if you are there, look for Turner Motorsport, and come and catch up.
simon
nah, no posers, it's all about fun...not matter whether it is a rallyx, or a rally, least you are out there skidding.
parts are getting hard to come by over here too, the rims are like hens' teeth and I rue the day if I do some damage to them. there are still some floating about, but getting people to part with them is the hard part...
mine is an 84 RX Turbo. been quite extensively modified for rallying which includes:
internal:
momo wheel
brantz tripmeter
sparco intercom
under the hood:
legacy radiator
FMIC
adjustable boost
dump valve
strut brace
drivetrain:
centre bonded clutch (forget the exact details)
suspension:
front: custom 50mm height adj bilsteins / adjustable bottom arms / legacy brakes / heavier anti roll bar
rear: koni height adj shocks
misc:
rims:
4 x 14" Enkei WRC alloys - http://www.ultimatesubaru.org/80s/wheels2/enkei_wrc_spirits_14_alloy.jpg
check out the car more at the site on my signature. we do the Top Half rally series in New Zealand. Have had a few engine failures in the last year, but next weekend (9-11th July) we are off to Rotorua for the Rally of Rotorua, which is a round of the APRC series, and the roads we are rallying on are the old stages from Rally New Zealand back in the mid 90's. Can't wait to get out and give it a nudge on the gravel
simon
bumps are so small, that from 10ft, they can hardly bee seen, no pics sorry.
what sort of application do you need a bigger IC for?
some of you should look at doing the FMIC route, it is so easy to do, and you get better airflow, plus limited heatsoak.
http://www.ultimatesubaru.org/forum/showthread.php?t=12639&highlight=FMIC
Denco Engineering in Christchurch, over here in New Zealand made up some forged pitons for my EA82T a year or two back. Weren't too badly priced @ $NZD1500.00 for 4. They are quite noisy, and have a very short skirt, got a good knocky knarly sound them.
Solid lifter are no good unless you are looking to make huge HP, and high revs, the std ones will do. Also, the solid one"s (I have a set from my last engine) take such a long time to adjust, esp when then engine is in the car and they aren't right. they are a real pain to get right.
cheers
simon
oh yeah, and a ea82 full time box with a impreza wrx ra gearkit, 4.11 diff on the rear, top speed 180km/hr, and you get there very fast, my Rx certainly does...took it out for a run in the weekend, running 14psi, forged pistons, FMIC, legacy radiator etc. etc, and holy subaru...it's quicker than my old stock Mitsubishi Glant VR4....have a rally on tarmac on the 24ht of this month, in New Plymouth, New Zeland, 200km of competitive stages...can you tell I am excited...
back to the topic, not sure how they did the gearbox, but it is fantastic
heres my 2c worth:
you could go for a fmic using the starion one, wouldn't be too hard to do, and with the fans running behind a new Legacy radiator, you would have a lot of cooler air flow, and not much heatsoak, and the car will run cooler.
I only run one on the downpipe after the turbo on the exhaust, it is the standard one which plugs into the green wire on the loom above the gearbox, has a black rubber cover on it.
I used to not even run one, but that made fule consumption rather on the high side
you could always do it the way I did it...see my earlier post
http://www.ultimatesubaru.org/forum/showthread.php?t=12639&highlight=bmfr
hey WJM
You have some mail.
thanks
simon
forgot to add, if anyone wants higher res images, then email me simon@terabyte.co.nz and I can send the two shots but in a much higher res.
this engine modification is worth the time to do.
thanks mike,
was going to go the WRX intercooler track, but I looked at one that had done a top mount with the Mazda IC, and thought to myself it would fit perfectly. Best thing is, it doesn't need a mount for the IC, as the boonet holds the pipes in place, all you need it a tie to the bumber to stop the backward movement, and presto, it is in. Took about 2hrs tops, the pipes were 15$ from Pitstop, the blow-off valve free, the IC $25 from wrecker, a bit of welding, and, some bumps in the bonnet, some filler, and bit of paint and presto, very low intake temps.
The expansion tank is from a Mercedes, my fater distributes new Merc parts, and it fitted without a problem.
PS, the hardest part was making up the new lower radiator pipe which comes from the water pump.
hey skip
the rad expansion tank, is it plumbed into where the heater hoses normally connect?
the tank has three outlets, one on the top fron comes from the top of the radiator, the one on bottom front goes back to the left hand heater inlet hose, and then at the back, there is a hose off the cap which goes to the overflow tank, which sits by the battery (with the red cap). The radiator is from a Legacy GT, not the RS. You need to do a bit of cutting at the front to make it fit (the lower radiator supports then need to be made up). This set up had dramatically reduced the temp of the engine, but it is yet to be tested properly, won't be til the first event in April 23rdish, a 200km Tarmac Rally in New Plymouth, here in New Zealand.
and how do you get the hood closed?
the hood has a buldge in it, only small, but one for each pipe. it is a little tight, and I have yet to get them right, but it fits a peach. The IC is from a Mazda 323 BMFR (the 1600cc 1987 model). The fan runs behind (on the radiator) and at idle, after the car has warmed up, the inlet pipe is hot, and the exit (to the inlet manifold) pipe is cold, so it works great.
simon
the idea is it pressurised the cabin, and forces the air out any small holes, and stops dust entering...oh and ventilation. I have some pop-up ones on my car, one above me and one above the co-driver, they blow a breeze past my face, which is great when the car heats up half way through a stage. you can buy some from the guys at Palmside
cheers
simon
hey guys
the answer to the oil is to allow the head studs to turn better when re-torquing them. just run it down a screw driver and onto the stud's head, and it will tighten better.
as for re-torqueing, I run a EA82T in my leone, which I use for rally's. I have had a terrible time keeping the headgaskets from blowing without re-torqueing at least once (we only run 14psi..so not heaps). also, we over torque them, the book says for the last one at 47, we go to 52 on the last re-torque, and hopefully that will keep em snug. have talked t all sorts of people, and the consensus is to re-torque once only, and some have said up to four times (OMG what **** job that would be...start up, heat up, cool down, cams boxes off, retourque x 4..)
that's my 2c worth.
simon
the squealling could possibly be a boost leak. Mine had a whine as it spooled up, and it turned out to be a boost leak.
86 EA82 cam noise?/oil pressure
Posted
additiive only quietens it down until the next oil change...waste of time, get them to replace the worn one if it is under warranty
