Mehoff
  1. Rooster2, would this also make the radiator fan run when it should not have been? and shut off when I unplugged the wiper connection? Thanks
  2. Imdew, Thanks for the info, The battery is new and I have checked all of the ground connections. So I guess that leaves the wiring diagrams..ARRG! I will let you know what I find.
  3. Hello, I have a 90 Legacy FWD with non-intermittent wipers that has been having a problem with the wipers. What happens that occasionally when I turn on the wipers they do not move and the light on the radio goes out. Sometimes it takes several minutes for the radio light to come back on. At one point I replaced the wiper motor but it did not solve the problem. Sometimes I am able to get out and pull on the wiper arms and they will start wiping but this is getting rarer. I have also checked the wiper transmissions and they seem to move freely when not hooked up to the motor. Today when they would not work I stopped and popped the hood and disconnected the plug to the wiper motor this did not change a thing and the radio light did not come back on with the motor plug disconnected. I also noticed when I popped the hood that the radiator fan was running and when I disconnected the wiper plug it shut off, when I plugged the wiper plug back in the radiator fan started again. This is the first time the radiator fan has been running when the wipers did not work and the car had not been running more than 5 minutes when I pulled over. All of the fluids are up to level so the fan should have not been on at all. Any ideas?
