Everything posted by matan stolero
weber carb on subi brat:
hello, i just a weber carb (36dca-rally) and i want to install it on my ea71 engine. i need yout help with gettin it fit with an adaptor plate. from where can i get one? (im from israel) is it posible to make an adaptor plate? anyone have sketch of that adaptor plate? thanks alot...
HELP - EA71 engine overhaul:
Hello guys, my ea71 engine is "STUCK" and need an overhaul. Is there any guide or good instuction that will help me do this from the beggining till it start? Thx alot...
Hello, need help - ej22 to vw trans:
Got ya, is there a sketch or instructions for making the ea to ej adaptor?
Hi all im working on fitting an ej22 eninge into my vw bus trans. to do that i know i have to get an adaptor plate and modify the flywheel. I have an adaptor plate i made wich fit the ea type of engines, is there any way i can modify the plate that it will fit the ej engine? or there is no similarity between those type of engines - wich say that i have to get a new plate? thx alot...
Help, strange noise from the engine (Brat ea71)
Hi I checked the exhaust and it looks fine. I'm pretty sure the strange noise coming from the engine, could it be from the valves?
Hello, last weak i drove my car for few hours, it did'nt get hot but suddenly there were a strange noise from the engine. It sounded like a working engine without exhoust and it get faster with the idle. what can it be?
swapping ea71 to ej engine:
Hello, I have a home made buggy based on vw beetle with a bus transaxle. Last weak I bought an adapter plate that fit the vw trans on one side and on the other side fit the subaru ea71\82 engine. I wanted to ask if is there any difrecne in the "housing" between those engine's and the ej18\20\22, i know the flywheel is difrent but i will make it fit. The adapter plate should fit the ej engine? Thank's alot...
Brat water leaking
Hello, I have a Brat model 88' with ea71 engine. Last weakend the engine becam warm and i saw a water stream came out from the engine. When i looked closer i saw it was from a narrow pipe which located under the carburator and behind the disterbutor. I think it was sealed with a tube that got ripped due to the warm engine. My qustion is how can i seal it, is there and stock part that will do this?
