seaweedpiano
Everything posted by seaweedpiano
  1. I tried to change out the stereo system in my 1988 GL wagon using color codes I found online that were specific to my car. I took the took off the negative side of the battery and wired up everything all nice like I did 6 months ago on my Chevy Nova. But, when I went to turn every thing on this time, the speakers were all crackly and awful and the dash illumination flickered a lot. So, I quickly took it off, but the dash never came back on again as I drove around! FFWD to today, when I decided to just put each wire to a meter using the black as the ground, I got these results: W/ BATTERY Green - yes W/ BATT AND IGNITION Green - yes blue/yellow - yes W/ BATT, IGN, ILLLUM Green - yes blue/yellow - yes red/green - yes with negative results for the red wire and yellow wire all the way through. So I assumed that that meant that: BLACK= ground Green= Battery 12+ Red/greeen= Illumination Blue/yellow= Ignition 12+ That made sense to me because ealier when I had the red/green wire as the "Battery 12+" one, the stereo would only turn on if I had my headlights on. When I put those wires together and went to turn on the car, it freaked out for about a half of a second, and now it wont start at all with or without anything connected. Which probably means that I fried something...? but the wierd thing was that even after all this, I disconnected the battery completely and was still consistently getting about 5V from the green wire and .5V coming from the blue/yellow wire. So where is that energy coming from?!? Also, I connected my car battery to the wall outlet so I can get it started at least, and now all I'm getting is a rapid ticking sound from behind the steering wheel. Great... Also, if anyone could tell me what are the real codes, I'd be really appreciative....
  2. WOAH! I'm an owner of a 1988 subaru GL wagon and I've been looking for Hours for someone with the same problem as me! Mine is doing all the same things as yours. I had the water pump and timing belt replaced a couple weeks ago and there's been no change for the better. One of my friends thinks it might be an o2 sensor and so I would like to know how to track it down so I can change it out. I'm not very knowledgeable about cars, though I'm pretty smart about these sort of things. Can someone let me know if I'm getting in over my head? I'm an engineering major at college but I have no idea where to look for things like this in a car. Thanks so much!
