coach9
Posts posted by coach9
No none there that I can see
None there that I can see and not 1 liste on the cover but thx for the idea
I have no turn signals but the flasher's work so the bulbs r good I think is there a separte flasher for the turn signals,if so where is it located?
Looks like ur on the right trail!!
Have U checked ur exaust flow,sounds a lot like a back pressure problem?
Thanks everyone,I sang my version of Madonna's LIKE A VIRGIN and promptly went out and shut them off!
99 legacy SUS Had to install a check engine light and sparkplugs,did that hooked the ground on the battery backup and now the lights won't shut off!!Is this a switch problem or should I look somewhere else?
Great stuff guys,I will use these suggestions in my search and will be doing the swap my self this time was the helper for the SUS swap!
Yes I did and it is dual ports,thanks for the info.Like I said I am now looking for something cheap this could be my backup motor or put in if the car has a bad motor. I think because these motors r cheap they did not want to pay the frieght to ship it back!I don't feel bad because it took them a month and a half to get me the right engine,so the extra one is a small compansation for their mistakes.
I have already gotten the 99 back on the road,with a 25.I was sent the ej 22 first it was suposed to be a 25,then they sent a 25 and never picked up the 22,so I am now looking for something cheap to put it in and have an extra for me.The 99 was for my son!
Thanks I have know characters stamped on the side of the bell housing rectangle,there r numbers stamped on the top,will they help?
I will Check that tube I will be putting in a new fuel filter.
I googled and found it was low fuel pressure,so u r on the right track.Where do i find the fuel filter tube on the 2.5?
Got this code when it failed emission test in Maryland,anyone know what it is?
Fixed the cruise,iwas a VAC line over on the passenger wheel well!:banana:
The cruise worked before the engine swap,fuse is good.I see a vacum nipple that comes out of the firewall it is on the drivers side of center I think this may be the problem.if so where do I conect the hose to when I get a new one.
The sunroof is slightly out of position after I manually adjusted it. The passenger side arm that operates it is disconnected or broken end therefore dose not operate is it a big job to fix one of these or relativly simple?
I forgot I need info on a failed emmisions guy ave me a code I think its a Subsru code p1440
Just wanted to thank everyone for the help,went with the 2.5 the engine turned out to be good even though the plastic cover where very damaged!
I can't find the the threads u mention,ru speaking about covering the light with tape.That will be hard to get by emmisions!
I will be putting in the 2.2 engine,how do I solve the CEL light problem since the 2.2 has no EGR?
U figured out my nine fingered typing just fine so what ur saying is it need to be separated with some force! I am now thinking I should put a little tension on the motor also. I wasn't thinking I needed to do anything the trans or its supports,I will give ur suggestion a try THANK U
It now seems ro me upon further review and know success getting the engine to come loose that te engine needs to be moved forward in order to clear the bottom studs.Can someone tell me the proper method to pull one of these engines or point me to a thread on here that tells me how!
Thank gentlemen I will be back at it tomorrow arm with my new info!
I have removed the 2 motor mount nut from the bottom, the exaust bolts,all the incidental wires hoses ext. what I need to know is there more then the 2 bolts at the top of the belhousing and 2 nuts at the bottom I see many more holes on the replacement engines but can find no other nuts or bolts,did i miss any
97 Lagacy Wagon turn signals
Posted
I have found under the panel under the steering wheel column to blk relays1 says ILLUMI CON UNIT it has 6 prongs[ =--= except the 4 prong r in line w/each other] the other relay says TIMER(15)ASSY I SAW ON ANOTHER SITE THAT The flasher should have 3 prongs HELP
