tomf31
Everything posted by tomf31
  1. the fusable link under hood is good checked it and the fuses with a multi meter not sure if the check engine light even works need to check the bulb
  2. Its normal turn over checked timing belt just to make sure its good just put on about 15000 miles ago. has 135000 miles on it the fuseable link in the fuse box under the hood is good is there any anywhere else?
  3. I also checked I have no power at the box on the fire wall and all fuses are good under dash and under hood
  4. I have a 96 outback with a 2.5 was running fine then it stalled now it won't start back up. I have no power to the coil at all new cam senser new crank senser new knock senser getting fuel good when first turn key on out of new filter. But have no power on any of the 3 wires at the coil with key on and cranking. all dash lights come on but the check engine light. Have searched on here and found nothing that has helped so far. thank ahead
