kiddo
  1. Bump to the top. OK I have another question. I just spoke the salvage yard with the trans. He is telling me that the numbers listed on the trans sticker (TZ1A4ZCDCA-RN) have to match or the trans will not work? When I questioned whats the difference he said the plugs were different and would not plug up? Can any anyone shed some light on what the difference might be? The trans I am looking to buy is from an 2001.
  2. Currently reverse is out. My aunt took it to our local Subaru dealership, and they informed her that the trans had a hole in the housing and leaking fluid and was not reparable. Personally I have not even looked at the trans to see if there is an actual hole or not. I drove the car home yesterday around 18 miles. Reverse is just like neutral does not attempt to pull at all. Forward gears seem fine. Anywho figured I'd just throw another trans in and be omw. Found one locally out of 2001 for $600?
  3. Hello All, I just bought a 2000 Outback Sedan 2.5L with a bad trans. My question is I have found a decent deal in a trans from a 2001 Outback. 1. Will it work? 2. Direct bolt in? 3. Any components that will can/need to be swapped to make it compatible? Thanks in advanced My 1st Subaru so my knowledge limited atm. Kidd
