hotrodmann
Everything posted by hotrodmann
  1. many times the shaft comming out the back of the tranny is fine the problem is that shifter shaft that slides over the tranny shaft. what we usually do if you dont want to replace the shifter is to take the pin out and find a grade 8 bolt that is the same size at the hole in the shaft. usually you will need to press it in and put a lock washer and nut and you will need to tighten it down as tight as you can but it has worked for me many times. good luck.
  2. hello everyone im james from the springs i have a 84 gl 4x4 wagon with a self made 3" or so life i have chevy/toyota 6 lug crome wheels on it. it is still a project in the works. i work at a car dealership and i got it for a dollar and have only put about $20 bucks in it thus far. i have 10.5" of clearance at the diffs with 205/75R 15's on it that i got out of our used tire pile. it now has 230,000 on the odometer and runs great. the only issue i am having is at about 40mph the steering wheel wants to shake my arms off. but soon i will have that fixed hopefully. then its up in the mountains. when i was young i used to mud race subbys i got out my dads junkyard and did verry well. ive always been a subaru nut and love it when someone says "why put a lift on such a turd" then i put it in low transfer and start climing stuff and then they understand that you never put down a subby
