goodkarmech
  1. I wanted to share my sunroof leak fix with everyone. On the double sunroof wagons blowing compressed air into the front sunroof drain doesn't clear the drain, it blows air out of the front drain of the second sunroof. Evidently they are connected together to share the same drain hole behind the plastic inner fender. So, I removed the few attachments of the front plastic inner fender to find 6 inches of caked dirt and mud jammed in there blocking the drain. Once i cleared out the dirt, I used a small piece of automotive wire to run up the drain hole. Only had to go a couple of inches and a column of water cam flowing out. Now the sunroof no longer fills the map lights with water!!
