Hey all,
I have an 86 Turbo XT (EA82) that's had some serious power issues lately. The engine seems like not all cylinders are firing. The car pulses/shakes back and forth at idle, and almost seems like it's going to backfire. It struggles to start from a stop or climb even the slightest of hills - I often find that it doesn't start really moving till the turbo kicks in or I apply wide open throttle. However, it's fine on flat roads above 35 mph.
I checked the timing with a timing light - it's apparently correct. I checked the spark plugs, they were all sparking, but I decided to replace them anyways. I replaced the cap and rotor. I replaced the O2 sensor. I ran a compression test - everything tested consistently. I found that the fuel injector connectors were corroded, so I've ordered new connectors that I will wire in. I figured the culprit was a bad connection and that a cylinder wasn't getting any fuel. I also ran seafoam through it in case an injector was clogged. When it was smoking from the seafoam, I noticed some coming up out of the engine around the turbo. I don't think it's related, but there's an exhaust leak somewhere.
Today I took off the PCV valve on passenger side (the side that seems to be running funny) and it stank of fuel. The valve on the other side didn't. Do I actually have a blown head gasket?
