how to diagnose noise?
My 91 Loyale has a noise which sounds to me like road noise. It starts at about 30 mph and gets louder as I drive faster. It doesn't seem to 'speed up' as rpms increase like a bearing noise. But it does get quiet when I turn right sufficiently sharply, which I have seen with bearing noise before. The noise may be in the front end since I raised the front end and ran the engine with the car in gear and it seemed like it was making a noise but not nearly as loud as when driving. It's not the tires, since I put different tires (on the front) and the noise still exists. I can't feel any heat in the hub area after driving which I might if the wheel bearings were going. What else can I do? any suggestions are welcome.
cam seal retainer bolt hole stripped
Changing the cam seals, I was tightening the bolts on the retainer. I forget the proper torque, something like 6 or 7, but using a torque wrench to set the torque, one bolt on each cam tower never reaches the set torque, they just turn. I removed the screw and looked in the bolt hole; the threads don't look bad, no aluminum filings inside and bolts do get fairly 'tight', but I'm worried that they might work loose. What should I do: 1 Tighten them as far as they will go and call it good. 2 Use some thread locker. How hot will the cam tower get when engine is running? 3 Use thread inserts. I don't really feel like going back to the junk yard for some cam towers, and who knows they could have the same problem?
how to set idle
Gents, I have a 91 Loyale with SPFI. How do I set the idle? I have seen at least 3 different methods in various manuals. One says to disconnect a line ( I can't figure out which line) and 'clog' it. One says to disconnect a connector (not sure which connector), set idle to 550, reconnect and check that idle is 700. I forget the third. What is the procedure for this?
head gasket, which way?
Thinking about while driving around doing errands today, I realized that they can only go one way. I will have to look at them again, but I think that makes that question moot. But staying on the head gasket subject in general, I've seen some references to retorqing the heads and that the Subaru manual specifies that that should be done. Can anyone give some details? Just turn it on and run it until the coolant gauge shows its hot?, drive it some number of miles? Can you do it by taking the valve covers off or do you have to remove the cam towers?
Bolting on heads yesterday and I don't know which way they go on. I see no sign on the gasket itself for 'top', 'front', left right etc. They are DNJ gaskets if that means anything. The metal rings around the cylinders are separated on one side and joined together on the other side. On the joined side there are sort of rubberized beads around the coolant passages. Does this side go towards the head or the block or does it matter? I bolted one on before I thought that it might make a difference. If I have it on wrong can I remove it and put it on the other side or do I need new ones? Car hasn't run obviously. I bent one corner of both gaskets trying to get it out of the plastic package. Will that matter? I have seen on this board that folks say not to use sealants on the head gaskets. What is the reason for that? If one did use sealant, what would be the best kind?
Head lapping with sandpaper
I resurfaced my E82 heads following the method discussed here. It took days and hours per day to accomplish. One of the exhaust valve guides was out of place in each head and after trying to press one back into place myself and cracking the guide, I took it to a shop to have those two replaced. They inform me that there are cracks between the valves and that they all have to be ground out and welded, and then the heads would have to be resurfaced since the heat op the welding would warp the heads. After reading up on head cracks on this forum I could see that the cracks went in pretty far so I went to the junk yard and procured two heads with only the beginning of one crack. Now I am resurfacing the heads again and many hours into the process. I start with 150 grit sandpaper and even put about 5 pounds of weight on the head to increase the pressure and it goes soooo slow. I see from the original thread that people were doing a head in just minutes. What the heck am I doing wrong? Also how much of the fire ring needs to be removed? That is the last thing to go and it takes forever. Lastly what else sould I look for on these heads? I never heard of the crack thing until the shop pointed it out (and they didn't look like cracks, they looked like a casting seam or something). Is there something else that I should look for that might render the head bad?
cam tower o-rings
Well they are flat and look something like a washer, yes, so maybe I have the right part. The old ones that were not 'metal reinforced' - they just looked like a standard o-ring?
Oil in engine cylinders
With the heads off my 91 Loyale, I was scraping carbon off the pistons then turning the crank to withdraw the pistons and wipe out the cylinders. Doing this a couple of time, I noticed that the front two cylinders always have some oil in them after turning the crank so that the pistons are in. That doesn't seem normal to me. Oil scraping rings shot? It was burning a lot of oil. I figured after seeing the heads that the majority was coming past the head gasket and some maybe through a bad valve seal. But maybe that is not the whole story.
cam tower o-rings
I've read on this forum several times that the genuine Subaru cam tower o-rings on the Loyales was metal reinforced or something? I just got a pair that I ordered using a part number that I got on the forum here and they cam in little sealed bags that seem to be genuine Subaru o-rings but they have no metal. They are entirely rubber and they came from Subaru Parts Warehouse. Did I get scammed? Maybe they no longer make them with the metal? Maybe I misunderstood all along what they should look like. Mine is a '91 and the o-rings that cam out were all rubber (brittle but rubber).
misplaced valve guide
Looking at the EA82 heads which I recently removed I see that one valve guide is not in the right position. Looking from the combustion chamber side the guide is flush with the head so that it sticks out more on the cam tower side. I don't know what happened. Did it somehow work out of place during operation? Was it not seated correctly in place during installation? I didn't notice any damage to the valve but will have to look more closely. Has anyone ever seen a case like this before? Do these valve guides move like that? I was going to lap the valves and surface the head myself but now I will have to have a shop install a new guide. But will a new guide move again or do I need another head/
hydraulic lifters
Well the engine has 300,000 miles on it and they do make some noise. It was burning oil, which looks to be due to oil leaking into the combustion chamber past the left side head gasket, but as long as I had it apart I thought I would check everything that I can get to. I was just going to replace them all but seeing how expensive that would be even to just have them all rebuilt, I thought it would be better to evaluate them if possible.
hydraulic lifters
I have the heads off my 91 Loyale engine and was able to remove one lifter. I can't see how they are supposed to work - should they compress, expand or what. Should one be able to induce movement in them at all? see wear? How do you assess the condition of these things?
bushings
I can't see any play so I will have to look into the alignment, I guess. Are you talking about toe in and saying that it should be toe out?
bushings
Is there a place to buy bushings for Loyales? Not the bushing for struts which seem easily available but the other bushings in the steering system. In general the availability of parts for Loyales on line (at places like NAPA, ROCK AUTO) seems very poor. The stabilizer bar that runs front front wheel to front wheel, I can't think what it is called, has two sets of bushings an inner set and an outer set where it bolts to the lower control arm. The inner set seem to fit very loosely. Are they supposed to be that way? My 91 Loyale tends to suddenly veer across the lane. It will steer straight for a while then suddenly veer the other way. On other occasions it will steer left to right to left and repeat, not much but rhythmically. What could cause this? The usual first suggestion is the tie rod ends but I can't see any looseness there. Is there a good way to check that?
clutch replacement
Thanks Gloyale. Does the putting the parking brake on change the position of the hill holder cable? That is, does the parking brake need to be off to adjust the cable?
dltrial
