:banana:figured out the problem by accident
unplugged map sensor and prob solved just needed to clean it now car is perfect
thanks everyone for all the input
Timing set with fining light to 20 deg with green conectors connected
Like I said idles perfect but no power and backfires under load
Yes I did unplug green after setting timing
And no codes what so ever
rechecked cam gears
Flywheel at three marks
left is at 12 oclock in line with the grove in the cover
Right is at 6 oclock position
turn flywheel 360 deg to three marks Again
now left at 6 oclock
and right is at 12 oclock
firing order was set 1,3,2,4
is it possible the valve lash is way off from last person to work on it
Just replaced timing belts on my 89 GL EA82 followed the link on here, turn crank till 3 marks one cam up turn crank 180 other cam up turn till timing marks install dist adjust to 20deg
idles perfect but backfires and now power driving
Please Help:eek:
