Last Foresters
wkoepp replied to Tom Dunn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWith these gas prices it may be the last year for the 6 cylinder models!
Roof Rack Kayak Accessories
wkoepp replied to SubaruLegacy2003's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet a Thule rack made for that year & model and you"ll have the best and safest.
Obd Codes
wkoepp replied to gyuunuuya's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou'll have to look in the manual for that model of scanner. My OBDII scanner says 23 is the "B" camshaft position circuit, 35 is the Turbo bypass valve circuit, and 52 is the HO2S Heater control circuit. Helpful ? I don't think so; if you don't have a manual, don't bother to scan it.
Air filter study - very interesting
wkoepp replied to Spokane-Pete's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnytime someone makes a big point of telling how much this or that expert test would cost to do and how expensive the super testing equipment is, it rings a warning bell in my head. You can put whatever filter you want on your diesel engine but a K&N filter will always go on my subaru and my mazda. Oily filters beat paper filters in California!
Jiffy Lube, reasons to avoid...and a big question..
wkoepp replied to Buddythedog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt depends, our Jiffy Lube is owned by a family that work there and they do good work, even installed a heat shield on our Forester - no charge. As for oil changes, it does no good to try to convince someone that 3k oil changes pay off in the end, because few people keep a car as long as I do. I sold my pickup at 120K miles and a Toyota at over 200 k miles, they're both still on the road. I follow my own advice not my buddies or a dealer. An oil filter doesn't catch all of the tiny metal filings and crap, I know that when they're drained from my car they won't wear out my engine. It's your car, treat it any way you want to.
mirror thingies on my mirrors...
wkoepp replied to starkiller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThen later on, if you change lanes and smack the car in that blind spot on your left you may put it back on. I have small curved mirrors on the driver's side mirror on every car and at least once or twice a year they show me a car or motorcycle riding close on my left but the big side mirror doesn't show it.
Online Service Manual
wkoepp replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's the one thing I'm disappointed about, they're charging you to peek at the service manual, then putting a limit on the time or the amount of the manual you can download. They have several plans and fees. Some owners have bought a CD off of the net for a few bucks with the entire manual on it, others say that a CD doesn't have the electrical diagram on it, others say buying the CD is immoral, they wouldn't do it. I have a couple of Mazdas and the service manuals can be purchased in a smaller version than the three ring binder monster for a few dollars. I don't remember what the Sub. factory site is. If you have an older subie you can probably get an aftermarket manual at any large auto supply.
'04 Forester XT Tranny Problems (already!)
wkoepp replied to BuffaloSubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have an '04 Forester XS automatic with just 9k on the odo and it shifts very smoothly, so it must be the turbo mods that make the difference or do they put a heavier auto tranny in the XT models? I doubt it. I just installed a heat shield on the exhaust pipe under the rear CV boot, as that boot rots much faster on the Forester due to the extra heat on it. Hope this helps extend the life of the boot. When are the car makers going to go to a boot with a zipper or some other closure so a replacement won't take so much labor?
Hello to you! / car break in period?
wkoepp replied to Zephyr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd stop every 1/2 hour for a few minutes to stretch my legs. We had the oil changed in our new subie at 1000 miles to get rid of any metal particles that weren't trapped in the oil filter, then I change oil every 3000 miles; I refuse to let oil go longer than that despite what any owner's manual states. My old toyota had 220,000 miles on it when I finally sold it to a guy for a work car!
Exploded Battery!!!!
wkoepp replied to fairhurst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should check the water level in the battery twice a year, a battery low on water has more gas in it than a battery that has had regular maintenance.
This is why I will never trust mechanics
wkoepp replied to q240z's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI only go to dealerships or major shops that appear well equipped and here's some things I've discovered when I brought a car home from a shop (no subarus): oil filler cap left off (car smoked until I found the cap lying there) heater hose left off (cost me a tow job) battery caps left off smog hose left off spark plugs not even finger tight (amazing that I got home) tools left on the engine (so cheap I tossed them) ignition left dangling (saw that before taking the car) oil spilled on engine top (I keep a really clean engine bay) Those are the shops I don't return to.
Thirsty Forester - how come?
wkoepp replied to Nashwill's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI took off the roof bars, aired the tires up to 34 and turned the AC dial up from 65 to 75 so it doesn't run all of the time; haven't checked the milage since so I don't know what it is now. It's a great car, hope it lasts as long as my 220K mile toyota tercel did.
2004 Subaru Forester gas mileage issue
wkoepp replied to ksarkisian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOur '04 is the same, I took off the roof bars, aired the tires up to 34 and turned the AC dial up from 65 to 75 so it doesn't run all of the time; haven't checked the milage since so I don't know what it is now. It's a great car, hope it lasts as long as my 220K mile toyota tercel did.
Heat shield for CV boot
As the left rear Forester CV boot has a shorter life due to the proximity of the exhaust pipe, I'm installing a proper heat shield on the pipe, just under the boot, so I don't have to pay someone to replace the boot earlier than necessary. The heat shield can be had at most hot rod sites or at J.C.Whitney: http://www.jcwhitney.com/webapp/wcs/stores/servlet/Product?showCustom=0&Pr=p_Product.CATENTRY_ID%3A2006315&catalogId=10101&Nty=1&productId=2006315&Ntx=mode+matchallpartial&Ntt=heat+shield&Ntt=heat+shield&tmplframe=EndecaControllerView&langId=-1&storeId=10101&Ntk=AllTextSearchGroup The part # is ZX501643N Bill
Thule rack question
wkoepp replied to Jman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI use a Thule rack on a 4 runner, I'd get the Thule clamps they're very solid and they lock. Give them call and order overnight delivery if necessary: http://www.thuleracks.com/thule/default.asp Good luck!
wkoepp
