lingcod
Everything posted by lingcod
  1. the coils on my resistor were broken i used 20 ga , 30 ga saftey wire to make new ones and soldered works grate all speeds are back
  2. the aft most line should go to top of radiator
  3. thanks for the help and is there a on line brake down image of thistranney thanks again and have a grate day
  4. hi my traney is a 4speed auto full time 4wheel dive and is the inner shaft on traney made to come out with torque converter thanks again
  5. hi every one i have 1988 gl wagon turbo i just changed the engine now when i put in the transmission did not want to seat at about 1/4" left so i turned the crank and bolted up when i went to start engine run and made a sound like spliens meshing and stoped also when i pulled engine the inner front shaft on trans came out with torque converter so put back in trans. thought i would say that. so when i put in gear car would not go till i reved up a bit its full of fulid and now it doesent move is it my torque converter or is there a vacume modulator on this? hope some one can help a new member. i just pulled engine back out and the torque converter aft side of flange has blueing and looking inside trans around shaft looks like loose snap ring also is there notches that torque converter goes in.
