scoobyru
Everything posted by scoobyru
  1. this is what im looking for! i have a 2000 outback and im looking for a kit. if you could get back to me that would be awesome!
  2. I'm not 100% I haven't had time to really look at it. But that's my guess. It has had the timing belt and water pump replaced once. I'm taking it into a shop tomorrow to see what is the problem. But it has 169xxx miles.
  3. okay so i have a 2000 outback. i need to know what i need so i can replace the timing belt and water pump. i am capable of doing it, but i also need some advice on how to do it. like the pricing of the parts and just basic stuff.. any help would be appreciated. thank you!
  4. I'm thinking so. Been reading that the late 90's and early2000's had that problem. May be dumb to ask. But are they easy to replace? Or should I take it into a shop?
  5. The timing belt was changed. I apologize for the wrong names. The water pump was replaced. It has 169xxx miles on it. I just bought it from a dealer. It looks like it is leaking from the front and passenger side seals and right by the oil filter as is there is a crack in the motor
  6. hey guys, i have a 2000 subaru outback, and i noticed the other day that it was leaking coolant, i need some advice on what i should do, it seems as if the coolant is soming from multiple ares, by the oil filter on the front part of the engine (just under the the pullies for the belts, right by the oil pan, and it seems like the gasket on the passenger side of the engine is leaking. need some help. please and thank you, Anthony http://s1217.photobucket.com/albums/dd393/Akingston82/?action=view&current=IMG031.jpg
  7. hey guys, i have a 2000 subaru outback, and i noticed the other day that it was leaking coolant, i need some advice on what i should do, it seems as if the coolant is soming from multiple ares, by the oil filter on the front part of the engine (just under the the pullies for the belts, right by the oil pan, and it seems like the gasket on the passenger side of the engine is leaking. need some help. please and thank you, Anthony
  8. i am having a same problem, i have a 2000 subaru outback 2.5i and i noticed anti-freeze leaking, on the hose just under the coolant tank, on the heat shield gasket (correct me if im wrong) on the front of the motor, where the pullies are. by the oil pan. need help and advice. help?
  9. i have a 2000 subaru outback, have to say i love it, 2.5i engine, but when i was driving it to work and stopped i noticed steam coming from the engine, when i poped the hood and noticed it was the engine but just underneath, it was anit-freeze. now it seems like the heat shield gasket (correct me if im wrong) on the front of the engine where the belts and pullies are seems to be the main leaking points. any ideas? also got to the oil pan looks very very dirty under there. need some ideas to see if i need to pull the engine or not.
