rhennager
  1. Thanks so much so far guys still not working. Can't get codes to read out via the grounding of the plug. Tried both with key on and key off when pluggin in the wire. Not sure if I have the right plug bcuz it's white and not black but looks the same as the one u sent me. If you could be of more help, please send me a message....SOON! thanks
  2. I have checked tps it seams to be working, because if i adjust it in any other direction then the setting that it ran with before engine swap, and if i change it the rpms go through the roof and do not fall. I'm also not sure how to test the trans codes. i used a code reader and no codes for the trany can up. is there another way to test it, and if so can you please give me some instruction how to do this. Sorry i forgot to mention the swap i did was the block and heads only. did not take anything off the intake or anything else that i did not have to
  3. ok I did an engine swap for friend in his 2000 outback and every thing went great until my friend came to drive the car. he found the at oil temp light on and flashing. So i got out a code reader and and the computer told me that it had a low tps input signal or voltage don't remember which but any way. Then we drove it, that is when i found the bigger problem. the car shifts REALLY hard. I have checked all grounds and all connections and found nothing . PLEASE HELP !!!!!!! I'M LOST
