freckles1
  1. I ran a new wire from the relay to the fuel pump. This has solved my problem completely. After testing the relay I determined that I had power to the relay and coming out of the relay, but it was not getting to the pump. Ran a new wire, problem solved.
  2. I have a 95 legacy that is having intermittent fuel pump issues. Replaced and tested pump. Works. replaced pump relay but may not be the correct one. I hear it open when the ignition is turned on. Test light shows little power at the pump. At times it will start if it sits or if I unplug the pump and plug it back in. this issue is driving me crazy.
