thunder
Everything posted by thunder
  1. The problem continued when checking on it last night, yes it was on again So, I took the rubber grommet off that covers the exterior of the switch and turned it upside down. This provided more pressure between the door and the switch and it went back out again. I am going to just get another door switch tomorrow and get a extra as they are not expensive and keep it in the glove box with the extra fuses and bulbs I carry. If one is going bad the probability of another is probably in the future so will have it on hand and take care of it. Thanks for your reply, I appreciate it.
  2. Thanks for your reply, after asking the question, went out for a closer look, found the switch on the door frame, worked it a couple of times and the light went off. Hooked the battery back up and the Subaru is race ready again!!! I will check the other door switches and get new ones of needed. Thanks though for your answer.
  3. Door ajar light is staying on and draining battery, I charged the battery but need to locate problem so this does not happen again. I have pulled the battery cable until I can figure out what the problem is. I believe there must be a switch either in the door or the engine compartment that is bad but do not know where it is on the car so I can replace it.
