tigger_18630
Everything posted by tigger_18630
  1. i know every body has been busy for the holidays and many thanks for all the help you have given me i was able to figure out the speedo and fixed that and motor and trans are in and every thing is hooked up but the car wont start and this was a running car before pulling motor and donor car was running and driving as well im positive all connections are hooked. quick back ground good car is a 95 impreza 2.2l with actual speedo cable and donor car is a 96 legacy wagon with electrical connection at speedo pickup i mention this because maybe there are wiresi need to hook up differently or parts i need to interchange from one motor to another im not aware of.im pretty sure it is electrical because i here the fuel pump running and i put a bit of gas down the throttle body after repeated starting attempts and more attempts after gas down throttle body that it should have made it to the cylinders as well negative on battery was disconnected whole time car was apart just over a week mentioned this incase a computer needs to reset im not aware of. i hope i have given enough info for someone to help me again and thanks in advance for your help.
  2. well finally taking out old trans to install new trans and found i have a speedo cable on old trans and new one had electrical connection can i unscrew electrical one and install cable setup and when i do could anything fall off into the trans diff. or is it worst case scenario and i have to swap diff. from old trans. to new and what pitfalls do i have when i separate the diff. from the trans. thanks so much for your help and merry christmas
  3. thanks adventure subaru for the help i fished the tube out of the trans and found the clip still on it and i was able to insall it on the tc.
  4. unfortunately i didnt know what this tube was for and let it slide back into the trans so hopefully the clip is on the tube becaus i dont know what the clip would look like and i hope i can fish the tube out without dissassembly
  5. well i made a bad decision and pulled the motor without unbolting the torqconverter. now my problem is how do i get the torqconverter all the way back in the transmission ive tried spinning and holding torq. level but i dont feel it has went in far enough pleas help any advice is greatly appreciated
  6. Knowing there are many cars to choose from due to being able to use other model years I would get a good used one just my opinion but thanks to the helpful people on this site I had the info to find a good donor and I did. Otherwise it would be awesome to put a 5 speed in it and a turbo but its my daughters car and she would be mad.
  7. thankyou very much, 284,000 and running strong but reverse just up and quit about 3 weeks ago engaged a final time the next morning when cold but with winter on its way gotta have reverse
  8. probably this question has been answered befor but i was told that only 95 engine and trans will fit in a 95 impreza cant use no other year and cant use a legacy. i found a 96 legacy cheap and woul like to get it for the parts can anyone tell me why any other year or legacy wont fit or is this false info my car is a 95 impreza l with 2.2l engine and automatic with awd i think its called a 4eat trans any help or insight greatly appreciated.
