terriep
  1. Thanks so much. The pully cable did come loose. Its blowing out cold now!
  2. We repalced the Rear Transmission Clutch Housing and Solenoid. My Subie now climbs right up the hill we originally tested it on. Before we had to pull it out with my Jeep.
  3. When I got this car it didn't have the ac belt on. We bought one and put it on the the ac blew out very cold. But the next time I tried the ac it only blew out heat. Is this a common problem? Should I start with the temp control switches or does this sound like a blend door problem? This is a 94 Impreza L 1.8
  4. I just got this car and discovered the rear wheels are not powered. We verified it has drive shaft and axels are connected. I heard these have some kind of clutch for the rear end. Is this true??? This car has the option if you add the fuse to be front wheel drive only. We installed the fuse and verified the light on the dash worked then removed it and still nothing?
