bans25
Everything posted by bans25
  1. If i knew the style of the flare, i was hoping i could find a lenth of tube that has this flare on one end and i can bubble flare the other end and patch it in.. i am pretty sure looking at this i need to do something like this. Does anyoen have any rust free part cars laying around that could cut a section of pipe? :).
  2. Just to be clear, the leak is outside the car, not inside the car..
  3. I have a fuel leak in a 2007 Forester under rear seat. Does any anyone know the line size (and type of flare) used on the Hight Pressure fuel line(yellow line in pic)? I need to make something up to fix this but do not want ot pull it apart (still using the car) until I have the parts I need. Or is there a repair kit out there to fix this? Thanks much, any help is appreciated.
  4. Hi all, 93 Subaru Legacy 2.2 and it will not start.. ran rough then quit (I wasnt driving it at the time) I believe its the cam or crank sensor.. The timing belt looks to be turning when I crank over. Is there anyway to test the crank and cam sensor? Also why are the 90-93 cam and crank sensors expensive and the 94+ are much lower priced? Can the later ones be used in the earlier cars? If not where is the best place ($) to buy new sensors? thanks all!
