warlockuy
  1. Thank you very much, you have a carburetor? sorry for my english I'll try to explain better. pump with regulator and I have everything installed and working. but the subaru carburetor used to control the fuel pump, rpm sensor. a black box below the steering wheel. this box is burned when using other fuel pump than the original, I was told that subaru Uruguay is the power consumption of the pump. you know anything about this? I can not put a relay to the pump and not use the sensor? Tell me about your subaru? very very thanks from Uruguay Rafael
  2. hello sorry for my English. I have a subaru gl 1.8 carburator I have a problem with the fuel pump. I put one that is not the original, a pressure regulator, and leave it ok. Now it turns out that day, I burn sensor revolution. pump seems to need more energy and burn it. how I can fix this? I put a bomb out? solution is put another sensor revolution? another brand and it will not burn? I recommend? thanks
