hdbavn
Everything posted by hdbavn
  1. Hi Ricearu - Could you tell me how to fix sticking torque converter lockup solenoid? Thanks
  2. Hi SubeeTed, I have similar problem. Did you get the problem fixed?
  3. the automatic trans fluid looks red. No it does not jerk hard when I downshifted. Thanks
  4. Hello, I have 1997 Subaru Impreza Outback with automatic transmission. After first 4 miles the car is ok and the gear is in "D" but when I stepped on the brake at stop light then the engine RPM goes to below 200 RPM then stalls; start the car again then the car runs very slowly even pushed hard on gas pedal. But if instead stepped on brake pedal I shifted to "3" then "2" on automatic then engine not cut off at stop light. Check Engine light with code 1507 (IAC problem) so I changed new genuine IAC with new gasket, cleaned MAF, speed sensor, throttle body, new battery, plugs, air filter but still have problem. Please help
