hdbavn
Posts posted by hdbavn
Hi SubeeTed,
I have similar problem. Did you get the problem fixed?
the automatic trans fluid looks red. No it does not jerk hard when I downshifted.
Thanks
Hello,
I have 1997 Subaru Impreza Outback with automatic transmission. After first 4 miles the car is ok and the gear is in "D" but when I stepped on the brake at stop light then the engine RPM goes to below 200 RPM then stalls; start the car again then the car runs very slowly even pushed hard on gas pedal. But if instead stepped on brake pedal I shifted to "3" then "2" on automatic then engine not cut off at stop light. Check Engine light with code 1507 (IAC problem) so I changed new genuine IAC with new gasket, cleaned MAF, speed sensor, throttle body, new battery, plugs, air filter but still have problem. Please help
Engine stalls when applying brake at stop light
Posted
Hi Ricearu - Could you tell me how to fix sticking torque converter lockup solenoid?
Thanks
