mrtoyou7747
Posts posted by mrtoyou7747
  1. OK
    I'm trying to change out the knock sensor. I can't seem to break the bolt loose. I'm afraid to put a lot of beef on it and break the bolt so I've been spraying it with Blaster on a cold and hot engine. The thing won't budge!
    Does anybody know who much torque this bolt can take before it breaks? If I knew I'd get the torque wrench out and give it a try
    I can't imagine what a PIA this could get to be if I had to easyout the broken remnant
    Any ideas?
  2. I had it. If it goes away with the fuse it is the C solenoid. (Use a 10 Amp fuse)
    Change the front and rear diff fluid with synthetic It gave me over a year before I had to bit the big one and change out the solenoid.
    Also when I got into the tranny I found some burned fluid on the output shaft near the solenoid. Turns out the lines to the radiator were clogged. check them out. I also installed an external filter from an older legacy. (mount on the inner fender.) No problems since then (80K miles)
  3. I found this procedure a couple of years ago on this site or via Google. I tried this and it worked.
    "Subaru recommends the following conditions and drive cycle to get the monitors on its vehicles completed in the shortest amount of time:
    1. Make sure the fuel tank is between one-quarter and three-quarters full; half a tank is ideal.
    2. Start the engine and immediately drive the vehicle for at least 15 minutes at a speed greater than 50 mph. During the warmup, try to avoid sudden acceleration, hard braking and/or lane changes.
    3. Drive the vehicle at a steady 55 mph for three more minutes. During this stage of the drive cycle, it's crucial that you keep throttle angle changes to a minimum.
    4. Bring the vehicle hack to the shop, hook up the scan tool and look at the status of the readiness monitors. Repeat the drive cycle, if necessary."
  4. I recharged my '98 two years ago and it still works great!
    Make sure you use a gauge to check the pressure as you fill it. As long as it's just a slow leak it the AC would stop when the pressure was lower than required.
    As long as there is some positive pressure in the system you shouldn't have to vacuum it out. But if you don't you really need to have dried out.
  5. The fuel filter for a Sube OB is under the hood on the drivers side. It's quite easy to change. (See other posts)
    There may be a screen on the pickup tube by the fuel pump (Forgot which side but the one with the most wires on the connector). I have never heard of any problem with the screen.
    Use a little silicone grease when you reconnect the hoses so you can take them off the next time. If you screw up the hoses make sure you use the correct pressure rated replacement hose.
  6. Here's some Info from Consumers Report latest test - First numbers are cost (small to large size) and the last number is rating. blue check is "best buy". The whole report is on line at their site (Nov 08?)
    recommended.gif Valeo 600 Series $9 $15 72
    recommended.gif RainX Latitude ftn1.gif 17 21 70
    Best-Buy.gif Anco 31 Series 7 10 66
    Best-Buy.gif Michelin RainForce 7 7 65
    Anco Contour ftn1.gif 18 20 65
    Valeo 900 Series ftn1.gif 20 17 64
    PIAA Super Silicone 18 24 62
    Bosch Icon ftn1.gif 18 22 60
    RainX Weatherbeater 6 10 60
    Trico Exact Fit 10 13 59
    Michelin HydroEdge 10 10 56
    Michelin Optimum ftn1.gif 16 16 55
    Anco AeroVantage 9 15 53
    Trico Teflon Blade 10 16 52
    Trico Innovision ftn1.gif 13 14 47
