Posts posted by juankyx206
so if this code 12, goes together with 11 and 13, this
Crankshaft Position Sensor, should be replaced, in order to use the loyale? -
today, also i check the timing and is on the mark, on the flywheel center marks, and the rotor is pointing at number 1 in the distributior, with the 10 mark point of the flywheel
the rotor, looks ok, it's moving when is cranking, and the spark plug wires are like a month old ( i pull a wire out, and has spark), and the car has a good fuel presure...
my 1986 loyale 4wd turbo, is just cranking but not starting, i just check up the ligth and I read code 12 " starter switch off position "... do you have an idea where is located? please, any ideas?
if you open maps.google.com you put Limache, Chile(that's my town), you will found that we are kind of far!!!
greetings
I have a stock turbo you can have. No play.
thanks, i'm in Chile, how we can work this one out?
Hi:
i'm a proud owner of a 1986 loyale turbo 4wd, the thing is the original turbo has shaft play and is leaking oil, i have seen some topic about the replacement...
there is any turbo direct fit from the family ihi from the subarus, (ex: wrx or b4), i need my car please:clap::clap::clap:
EA82T, with code 12 not starting
Posted · Edited by juankyx206
this problems start when I change the pcv because the old one was leaking oil to the intake, also I replace the air filter, but everything was put back in place, even every little vacuum hose, today when I rechecked the car has spark but looks like is little weak, and the smell of the gasoline fill the air, so looks like I´m having a wet spark o a bad coil....
thanks for your help
king regards from CHILE
:wacko: :D :wacko:
