timzoy89
Everything posted by timzoy89
  1. Fixed ! Well at liest that issue. Lol It ended up being the carrier bearing mounting bushings. Do those that dont know, the carrier is held in with 2 bolts. Those two have rubber/steel bushings to keep vibrations from entering the cab. I ended up having 1/2 of those 2 piece bushings backwards on each bolt. There for when the bolt was tightened down. The carrier assembly was still able to move up and down a good 1/4". After up and down with the bolts a good 5-10 times I finally noticed it was the bushings. Put back correctly and bam, no noise.
  2. its been a good 3-4 months.. between driveshaft failure and banging noise. the transmission mount is a good possibility (i never checked it) tomorrow is sunday so i can actually work on it.
  3. I like your thinking. I always trust my gut first & no only while driving thanks justin. I dont know if the axles were stock or aftermarket... i did how ever just installed a aftermarket one, but havent driven it enough yet to say if it helped or not... ( i did a circle in the subdivision and parked it for 3 days now) it was still making the noise but not as bad I replaced the drive shaft because the front joint exploded, which caused damage to the shift linkage. which i temporally fixed. and it just came loose again (4 months later) which is why i havent driven it the last 3 days.
  4. The drive shaft is brand spanking new, even had it removed and rechecked after the noise started. Conformation was the shaft is good. Carrier is a little week but ok. I'm confused, (I'm a truck guy) Is the FWD fuse - 4 wheel drive or front wheel drive ? I assume that it meens, front wheel drive only when the fuse is in place ?!? And I did just replace the Pashenger cv axle (aftermarket) but only now like 2 miles on it. I've been driving the truck these last few days. I have not even tried the fuse yet. Where is it located ? Under hood or interior panel
  5. I did not know that there was a fwd fuse. That's good info. I'll try that out Thank you.
  6. Hi all, im new to this forum, and fairly new to AWD car's. im about at my witts end. i have a 99 subaru legasy L "30th aniversery" 2.2L auto tranny. the car is making a very loud and noticable banging noise/vibration comming from the tranny tunnle area (felt the strongest) but the noise sounds like its comming from the pashenger inner cv axle joint. it dose it 100% of the time at slower speeds 0-35 mph and the most prominent when Decelerating to a stop (15 - 5 mph) it makes the nose during acceleration, turning, stright, and decelerating. it dose not make the nose at higher speeds but will make the nose/vibration (softer) when turning at faster speeds like a highway clover (40 mph 'ish) the noise basically behaves like a bad CV axle, but is making the noise and vibration of a bad U-joint.. thats why im stumped.. THE DRIVE SHAFT IS BRAND NEW, i even removed it once the noise/vibration started and had it checked by the manufracture (because it sounds like a drive shaft) the only thing i can conclude is that its the front diff. BUT I HAVE NO IDEA (im new to AWD)
