Posts posted by CrownIdeas
Has new timing belts, timed it with a light.. All new ignition parts...
13 year old gas? There is your problem right there. Dilute it with new Premium gas, in order to bring the octane up.
Well, I emptied the tank and scraped the tar out of the bottom of it.. At least as much as I could, but the new gas I put in may have mixed with the leftover residue... I'm going to run this tank out, and sea foam, and reafill it...
Seafoam may be a better choice.
a whole can in a tankful?
The car has 157,000 on it, but it has been sitting for about 13 years, so I will check those connections. I have blown air through the supply and return gas lines.. They seem to be free.. I'm not sure that the gas isn't still a little tainted.. I am trying to run this tank down before I get more gas. What do you all think about octane boost?
Check and clean all the Earth points on both the Engine and in the Engine bay when cars get a bit older these usually get higher resistance and everything works on voltage and high resistance means sensors see lower voltages than they should do and then the computer gets the wrong voltage readings and goes to the wrong look up table in the software telling it how much fuel or timing to supply.
It definately sounds like it is lean and seeing as things such as Injectors have been changed as long as Fuel pressure is within spec then high resistance in the Engine management loom at either the earth points of one of the connections can cause those problems, Easiest and most likely are the earth points to check first because unlike most of the other connections they are exposed to atmosphere and can and will corrode or oxidise.
I agree, it is running lean. When I check the plugs there is no residue or carbon buld up. They are tannish in color and the insulator is yellowed...
by earth points do you mean ground? There may be a fuel connections I haven't cleaned yet, but I have cleaned a lot of them already...
Loud fuel pump and sputtering sound like a symptom of rust clogging the pickup or fuel return line.. but you said youve already been through it. Same symptoms I had with a clogged pickup. Did you blow them out with compressed air? CHeck the fuel filter for residual sediment and stuff. If you think the fuel system is fine. Check your coolant temp sensor, timing and ignition over real good.
I'm pretty sure the pick up tube is clear, but never thuoght about the return line causing a problem.. I took the tank right out at one point, cut a hole in top of the tank and cleaned it out from the inside. I have chaged the pressure regulator as well. Maybe I will try run both lines into a gas can or just blasting the return with some air...
Ive idled it up with the cable adjustment.... Does the temp sensor in the radiator effect how it runs? It is currently bypassed so the fan runs all the time,, I have changed the ect in the top on the engine..
when it's warm it will idle, but it still runs like it's starved for gas or air. It kinda sputters and I'm sure it's not giving me the performance it should. Yes, the MAF has a flapper.. I tested that bypass valve with an ohm meter and it was within speck.. Maybe I need to see if it's stuck? are you talking about unhooking the bypass hose from the valve on the thermostat housing? Not sure if I mentioned it before, but I also bought a new maf for it...
I just remembered that I have an extra connector.
There are 7 total connections.
Starting from the left side.
1st slot has no wire
2nd slot has no wire
3rd slot, yellow/blue
4th slot, green
5th slot, blue/yellow
6th slot, yellow/red
7th slot, green/white
Thanks so much.. I am thinking I still may have bad gas in the system.. I'm not sure why it doesn't idle when it is cold. Ive put 3 different fuel pumps on it but they have all been kinda loud. They sound like they are straininig.. I have also changed the fuel regulator.. It looks like the wires are right...
Mine runs like a swiss watch, but I can't see which wires go in which connector on the plug. Try running some seafoam through the intake system. Usually there are broken nipples on the vacuum line system that runs over top of the engine, that screws up the idle. Your distributor wire connectors could be corroded either at the plug or at the distributor cap. The electrodes in the distributor cap, pick up corrosion fairly quickly that should be scrapped off.
I've completely been through the fuel system. Cleaned the tank, changed fuel pump, changed filter, and injectors, changed vacuum lines when I've found bad ones. Also, all need ignition parts; plugs, wires, cap and rotor... There is a boot you can pull off the plug to expose your wires, but if you don't want to do that, I understand. These cars are vintage and fragile in some ways...
I have a 86 GL-10 Turbo that I bought earlier this year.. It had set for over ten years,so it has been a project. I've got it running now, but something makes it not want to idle when cold and it hesitates when warmed up.. I bought a new Mass air-flow for it but seems to run about the same.. I was looking in the chiltons trying to test the MAF and it appears some of my wires are swapped in the plug for the MAF. Does anyone have a GL-10 turbo that runs well so I can varify the wiring?
Do any of you have a part number for Hydraulic lifters for a 86 Brat? Someone gave me a Subaru part number but it was for an XT or something and they are not the same even though it was for an EA81 engine.
Hey felsubluvs,
that's fellow Subaru lovers. My name is Anthony. I'm glad to finally be a part of this online community. I have already read a lot of posts when I've been searching online. I know this will be a benefit to me and my GEN 2 soobs. I have some questions hopefully I can figure out where and when to ask them, or find the answers on here. I will try and post some pictures of my 86 Brat and 87 GL Hatchback.
Got a Brat for sale on Ebay
Posted
This is one of my Brats up for sale on Ebay..
http://www.ebay.com/itm/1986-Subaru-Other-GL-/322542983755?hash=item4b190f5a4b:g:RyQAAOSwlY1ZNJaF&vxp=mtr
