Gosdawg
Posts posted by Gosdawg
Sorry, I feel like an idiot posting so much for advice... But I guess that's what this forum is here for...
So here is an update on the oil leak...
So, I've been monitoring the oil leak...
The dip stick says my level is full, and safe (but it could be wrong?)...
I wiped down the oil pan, and the jack plate in front of where the exaust meets at the form and stuff yesterday, and today, on the commute, I noticed smoke at a stop light... So I checked it, some oil returned to all of those places...
The oil pan has a bead of oil dripping near the drain plug, but I do not think it is coming from the drain plug... The drips on the jack plate came back, or up maybe I didn't wipe them down enough...
But for sure, it is leaking onto where the exhaust forks, that is where the smoke is coming from. (it could be more than one place, but I saw that for sure). I even saw a drip fall onto the pavement there...
I don't know if it's anything serious, and I don't know if it is worsening because I've been running it a little hard (a lot of up hill, up mountain driving... A lot... I mean a lot). It seems like it has... But I cannot be completely sure...
I also noticed (when looking from the bottom of the engine) a hose on the driver side with a drip of red liquid (power steering fluid?) it also seems like where the engine and tranny meets there is a leak... (so many it seems, I hope this isn't a hopeless cause)...
I am really falling in love with this car... So I don't want to abandon it (even though i dont want to do with the leaks). And I wish I knew where they were coming from... But I imagine in the long run, it would be best to pull the engine and reveal everything... I'd like to know how hard that would be myself, or how expensive it would be for a shop to do it...
Maybe someone knows of someone near salt lake city area who could assist or guide the process?
And, in the mean time, as long as I monitor the levels and replace oil a d fluid as necessary, do you think it is a problem that could be waited on while the money is pulled together... Or should I be considering this a big problem that should keep me from driving anywhere... Aka the mountains (there are a lot around here), the desert (also a lot of those around) and so forth...
Nothing else is abnormally wrong...
I mean if I am hard on acceleration, it a rough shift out of first, but smooth otherwise...
Also, the steering is posing no problem... And aside from the smell of oil and the smoke, I don't notice the leak being extensively fast...
I have noticed a lack of power at times, but that could be from it being a 1.8, and not because I've been hard on it... But someone else would no know better...
Fair enough...
How would add dye to the oil, or should I...
There seems to be a slow moving leak, but over the period of a few years, it looks like it is everywhere... I kinda want to see where it is from... So, in response to that, How much would it be to reveal everything, or even swap to a 2.2?
By the way, is that green dye easily removed or washed away should I get it everywhere?
Seems like it would be better to just buy the calipers on amazon...
Indeed... Well well alright...
How would I test the calipers before I pull them?
Is this the same seafood stuff you buy at the auto store in the white cans?
I used it because I had some valve ticking a week after I got my impreza, then a week later, upon starting, the ticking got exceptionally loud (it got quieter as the engine warmed up), but the people at the store told me to use this stuff in the oil (which needed a change anyway), so I put half in the oil, half in the tank, drove it to park city (45 min uphill climb) and back, and when I changed the oil... Everything sounded, felt, rode, drove better.
Okay, fairtax4me, that is good to know, but if I do end up finding the shavings, what am I replacing, everything a/c related? What all is a/c related, there are the lines, the compressor, the condenser....
To coupedupsubie, that is useful information, I imagine it can be done cheaply if I find good parts at a junk yard, or do you think something else...
And about the awd conversion, if I decided to do that, should I upgrade to the 2.2, or is there something I can do to the 1.8 that will add enough power?
Oh, that's the dye? Yeah, I can see that now... It's really visible...
That's really good to know!
Who knows if it was too full, I just know that the hub on the compressor one of you is telling me about will not turn by hand... It nudged a millimeter to the left or right, but other than that, it's pretty rigid...
So according to you guys, I should evacuate the system, check the lines, replace the compressor, charge, and see what happens...
I can find compressors at the local pick in pull for about 30 bucks. Do you guys think I should go ahead and change the lines, regardless of the condition I find them in? Also, is there anything else I should be looking for? Or checking for?
Any procedure I should make sure that I do? (procedure explained in some detail if possible)
I'm starting to think that this IS a compressor issue, and the old owners mechanic (as someone mentioned) was lazy and/or dishonest and saw the ability to mAke a quick 1000 (quoted price to fix the supposed metal shaving issue)
However, I am still going to check the lines for these metal shavings to be sure...
Again, thanks for all advice and future advice.
Yeah, there is refrigerant left in the system, I was unbolting one of the a/c lines when I started to hear it hiss, then, all of a sudden, this like, super radioactive green color liquid squirted out, so I tightened it (I'm assuming that is the freon)...
I would have ran away for about an hour, but I'm worried about the green liquid stuff being corrosive or damaging in some way to the other engine components... Other wise, I would have a bright neon green engine right now :-p
So what should I do with the green liquid should I run away for an hour?
Anyway, I understand that my question are newbish... I appreciate the advice. Thank you. Further advice is also appreciated...
Okay, that is helpful information, and helps me think the I won't have much problem... It makes me wonder why the old owners mechanic would say there is... But either way, I think I'm going to check the lines like some have said, and so, I need a couple of answers based on the questions from my last post.
Again, thanks everyone for all the advice.
So, I was taking off the a/c lines, when, low and behold... There is still freon in there... I guess I should have guessed, (hopefully freon is not corrosive, if it is, hopefully someone will let me know)
So a couple of questions... How do I safely and cleanly, drain the freon out, so I can check the lines for metal shavings (or anything else weird)?
Also, I tried to turn the hub on the front of the compressor by hand, it does NOT move... But I see where there is an Alan wrench screw, am I supposed to turn with the Alan wrench, or by hand, because by hand, it does not budge... But of course, I know little about subarus because I came from a ford focus before this car (big difference so far, not a bad difference, just unfamiliar)
Also, if I take the a/c lines off, can I leave them off and be fine, should I cover the holes that they attached to, or should I reconnect them to be safe?
Thanks for all the advice.
Burning metal? Could be burning clutch on the compressor when it's engaged.
Large cylinder to the drivers side of the alternator is the AC compressor. Has to big aluminum lines bolted to the top. The pulley is composed of an idler (the belt rides on this) and a hub and clutch assembly that turns the compressor shaft. The outer section of the hub (the clutch) is pulled against the idler when a magnetic coil is energized. If the compressor is seized you will not be able to turn the inner hub of the pulley by hand, or it may feel notchy.
Be sure the engine is off when you try this. The hub is the section on the front with the triangle. Put your hand on it and try to turn it. Should be easy, with an even feel of drag the whole way around. If it's very hard to turn, or doesn't turn at all it's likely the compressor is damaged internally.
The smell could also be something strange in the heater core, or the blower motor is burning out.
Hm, but I only smell that smell when the a/c switch is on, otherwise (on vent, bilevel and heat) there is no smell... But I'm definitely going to check the lines and the compressor today or tomorrow at some point (I know I said that already, but it's been a busy weekend)
And to the second post, no, not the air filter... It's between that and the headlight... It's to like, a medium sized rubber hose and small on that hooks into it... I don't think the car has ABS...
Thanks everyone.
Is the compressor right there next to the alternator?
Also, what is that thing, front left of the engine bay, just behind the passenger headlight? I can't tell...
Okay, I will do that within the next day or two, and then I will post my results... I kind of hope there are no metal flakes in the lines, as I am kind of pressed time and money wise to replace nearly everything under the hood (unless you mean the just a/c system)
But either way... Thanks for the advice, and I'll try to come back ASAP
Sorry about that, I thought I mentioned that the car is an automatic transmission. So yea, it is an automatic transmission...
I will go ahead and change the transmission oil a couple more times, and change the gear oil as well...
And I will go ahead and start looking for a used compressor, and in the mean time I will go ahead and clean the lines out and see if anything comes out with it... Do you have any idea why I got the bad smell with the A/c on, but isn't there when the vent and heat is on?
But say weird things do come out of the a/c lines, am I just replacing those lines, or am I replacing everything... And am I worried about the condenser being damaged?
And as far as changing the timing belt, I think I could go ahead and do that myself... If its not too hard I won't even bother paying for the labor.
Thank you again
the "metal bits in the a/c" talk is usually not reality...particularly on Subaru's...but not impossible. if you believe it - then change the compressor and the two hoses that connect to it...and if you find it all in a pull it yourself yard, heck replace everything easily accessible which is a lot of the A/C. often mechanics will just say that without a robust look at what's wrong...if that's the case then it may just need properly charged, a leak fixed, or the compressor replaced.
good to get new orings in there anyway so might as well knock it all out at once and do as much as you easily can.
Auto: change the trans fluid and front diff
Manual: change the gear oil
I'd want it reliable so personally i'd get an ebay timing belt kit with new timing belt, timing pulleys, and tensioner and replace all of that. easy job on those motors and the kits can be had for $100 or less for everything. if the timing belt is original not only is it over twice it's mileage it's 20 years old, not reliable enough for me.
Make sure battery terminal connections are clean and tight to keep battery and alt happy.
Okay, we'll that's good to know, I'll definitely look into it more... Hopefully it is just the compressor and a matter of charging, but I should be sure first... Is there anyway I can check that my self, or I should I find a reliable mechanic to do this, or both?
Also, the PO claimd to have changed the transmission fluid already because he accidentally drained the TF when changeling the oil once... So I think that's taken care of, it was within a few years... Also, this is newbish, how do I change the front diff, what is that?
And I will definitely look into the timing belt kit... Is it pretty easy to change without raising the engine? Or should I take it to somebody and let them do the labor? I can be pretty good with a wrench, I am just asking if there are special tools I need to use (probably some I can rent from autozone or O'Reilly I bet)...
Thanks for the continued advice everyone
Hm, just the compressor seized huh?
Okay, So I will have that checked out, and if it is just the compressor, I can just replace that I imagine... But I'll definitely look around the junk yards for some parts...
Now you guys have said that the subarus are like Legos, and that parts from make and model differ very little if any? Can I get a mor specific year range and vehicle range?
Anyway, thanks for the advice...
And also, I imagine it's possible to turn the FWD into an AWD?
Plastic parts are cheaper... But are they in anyway reliable? Also what is most commonly made from plastic?
Sorry, I'm a newb
So I just bought a 94 subaru impreza wagon. It's 2wd, auto and has 141k... I paid 900 dollars for the car... The a/c doesn't work and there are some other things... I put a more detailed post about the condition of the car, and asking for advice in the general tech forum. So, if anyone wants to see the whole list of details (a lot more good than bad), and maybe give some info/advice, go check it out in the general tech forum...
But yep... I'm in salt lake city, so if there any other Subaru owners/techies, I'd like to meet up sometime, I could use some help working on the Subaru... I recently had a 2002 ford focus zx5 that I worked on, and upon popping the hood I was surprised by the H4 motor rather than a standard I4... Also wondering where a good parts store is, or good mechanics to do more complicated and technical issues.
Anyway... Hope you guys are having a good night/day
So, like the title said, I just purchased a red 1994 Subaru impreza L wagon...
It's 2wd, had 141000 miles, the a/c doesn't work. The engine sounds fine, the transmission feels smooth (not as smooth as my last car, an 02 ford focus, but it's still not bad). The impreza starts right up... And the motors are going out on the power windows... There is no check engine light...
But I was told by the previous owner (who claimed to own it since 95, but title says since 2002)... The timing belt has not been changed, he has claimed to change the oil regular... It was involved in a fender bender with a parked car, but no serious damage...
The A/c apparently went through some catastrophic failure... He explained (he claimed he could barely remember) that some metal or something had gotten into the lines and ruined the WHOLE system... I was also told by a quote he had gotten a few years ago to replace and repair is 1000 dollars... When I turn on the a/c, I get a real bad smell, that smells kinda of like burning metal, but I don't get it with the vent or the heat...
I know I should get regular maintenance done (I.e: change oil, change timing belt, check brakes and replace, maybe replace the brake drums? Change plugs and wires, clean battery terminals)
Is there anything else I should worry about, or made aware of? Is there any general mait. That I am missing from my list?
Also, is it possible to replace the rear brake drums with rotors and pads, or is that not possible to make that change effectively?
Oh, and I am sure this normal, but apparently the car will burn about a half a quart of oil over about two months, but the previous owner has reported no leaks of the sort... And the only leak he reported, was repaired, and not an oil leak at all.
I appreciate any and all help/advice that I can get...
Just got a 94 impreza wagon... Opinions?
Posted
Would a stop link be a decent quick fix for it? Or should I avoid them?
The leak doesn't seem as bad as I initially thought, but it's still hard to tell, I've been checking all day, put a half a quart of oil in there, and it went above the full line...
But still...
