benji131807
Everything posted by benji131807
  1. I have a Subaru Impreza WRX 2006. The check engine light came on and when I took it in to see the error code it came up as Error Code P2444 Fuel Injector or secondary air injector pump. Has anyone seen this code or problem before? The dealership says I need to replace the fuel injector, costing over $1,100 which is ridiculous. I have done some online research and some say I just need to replace a sensor that isn't working properly or that the fuse has blown. Have any of you seen this code error or know what else could be wrong or what to replace? Thanks. I have a Subaru Impreza WRX 2006. The check engine light came on and when I took it in to see the error code it came up as Error Code P2444 Fuel Injector or secondary air injector pump. Has anyone seen this code or problem before? The dealership says I need to replace the fuel injector, costing over $1,100 which is ridiculous. I have done some online research and some say I just need to replace a sensor that isn't working properly or that the fuse has blown. Have any of you seen this code error or know what else could be wrong or what to replace? Thanks. I have a Subaru Impreza WRX 2006. The check engine light came on and when I took it in to see the error code it came up as Error Code P2444 Fuel Injector or secondary air injector pump. Has anyone seen this code or problem before? The dealership says I need to replace the fuel injector, costing over $1,100 which is ridiculous. I have done some online research and some say I just need to replace a sensor that isn't working properly or that the fuse has blown. Have any of you seen this code error or know what else could be wrong or what to replace? Thanks.
