gold miner
  1. thankyou sickness am affraid that may be my prob. but how can i identify the trans to find out if it is even a fwd- or 4wd trans only. have not run across another one with only the one rod out the back that the select is attatched to- other than the one the 1-5 gears so only 2 rods out the back of mine.
  2. thankyou-the rod is there through to the case and the hi-lo works but no fwd only-i only have 4wd. and no vac switch as a rx
  3. from goldminer- thankyou have tried many times
  4. have a 78 brat with 1800 ea82 turbo with 5 speed trans with 4wd in h&l. the trans will not shift into fwd only. dont know if trans is only 4wd. does have hi & low. how do i tell. when i look at the back of the tranny from underneath the transfer only has one peg comming out the back side that the selector is attatched to which is on the passenger side. am wondering if this is a 4wd tranny only. the sn# is 658189. the reason for not knowing is bought the car with the engine & tranny switch done, so i think the moter came out of a rx?-rx?. also the selector faces the front of the car not the back as all of the ones in the wrecking yards iv'e seen. thankyou goldminer
