Passenger electric door lock
lemanu replied to lemanu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk Thanks
lemanu replied to lemanu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for your quick answer Glen. I guess you are talking about a bad or dirty switch in the driver door isn't it ? How easy is it to take off the part to clean, do you have to take off the whole door cover? Manu.
Hi all My passenger electric door lock has recently gone manual. It doesn't respond anymore to the central locking from the driver side (with the key outside nor with the switch inside). All other doors are still controlled without any problem by the central locking. The fuses are all Ok. Any clue where and what to look for ? Thanks. Manu.
Intermitent fault
lemanu replied to Mat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't know if it's the same trouble, just in case... I had a trouble with my 95 legacy: if I was running it for few kms, stopping it for 5 minutes, then it bloody wouldn't start again. I would have to wait for 15-20minutes before the car would seems to have recover and would then start again. Someone in the forum told me one day that it could be a problem with the camshaft captor but could also be the crankshaft one. I had had the crankshaft replaced before and it hadn't made any difference. However, replacing the camshaft captor solved this problem, finally. A user experience. hope this can help. Manu.
No electric windows nor ventilation
lemanu replied to lemanu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProblem solved. Looking at the fuse box under the driving wheel, I noticed a bad contact when pushing it (I could here a strange electric click). Pushing back into position most of the connectors solved the trouble. Thanks anyway. Manu
Hi all, A strange problem that occurs every now and then to my Legacy 95 : the car starts well but none of the 4 electric window switches are working, nor the ventilation... also, during these moments, pressing the aircon button displays the red symbol that warns you you don't have your seatbelt fasten even though its fasten. If I unpress, the symbol disappear. And then all of the symptoms disappear after few days. Don't know what's going on, could it be linked to high humidity (heavy rain this morning) ? I haven't checked the fuses for that yet, but that's my next task. BTW, does anyone know where are these fuses located ? I'd be happy to hear if someone else has ever had the same symptoms. Cheers Manu.
lemanu
