ZMaster
Everything posted by ZMaster
  1. Alrighty, it has been done! - Outback struts (Gabriel, to suite Outback BG9) - raised springs (King Springs, to suite Outback BG9) - ECB Type 8 bullbar (Also originaly made for Outback BG9) Fitting the bullbar wasn't to easy, as the front bumper is slightly different, but with a bit of cutting it's possible. All in all it got me a lift of 8 cm, which corresponds to a ground clearance of 26 cm (ground to lowest point of frame)! Now I'm currious how well it will do on the beach, thanks for the help everybody!
  2. Thanks for the hint. Yea, I want to get my Liberty (=Legacy) lifted using Outback struts and raised springs. Referring to earlier posts in this topic the Outback struts should fit in fine, no? The thing is the struts are not that easy to find in Australia, but on the US eBay there's plenty. The only thing that confuses me is that the rear struts I'm looking at are EXCLUDING air suspension, while the front ones are explicitly air suspension ones, does that matter?
  3. Hey, I now got the raised King Springs for the OUTBACK BG9 to put into my Liberty (= Legacy) Wagon '96. I'm still looking for struts to go with the springs, is anybody able to tell if these struts would go into my car without probs? http://www.ebay.com.au/itm/281120445470 http://www.ebay.com.au/itm/120653716554 Thanks, Nils
  4. Makes sense to me. Probably hard to tell how likely that would be, e.g. every time I go over a speed hump, or just in extreme situations. Would that harm the vehicle in some way or just feel nasty?
  5. Thanks! Yea, the legacy is just the same as the liberty, just a different name over here... I'll probably get some outback struts from the wrecker then, sounds like the most practicable idea. Just in case I don't get the struts: Whats the worst that could happen if I use the taller springs with the short struts in terms of "toping out"?
  6. Hi everyone, A guy from offroadsubarus.com recomendet this place, for finding out if what I have in mind would work out: I have a Liberty (yes, I'm from Australia) Wagon '96 and I wanted to give it a lift by putting raised King Springs in. Now the problem is, that the product cataloger of King Springs doesn't list raised springs for my model, but for the Outback of the same generation. Has anyone experience with that and knows to which extend the suspension parts are interchangeable for that 2nd generation e.g. would it be possible to fit the raised King Springs for the Outback to the Liberty, or would I need the Outback struts as well?
