opstech438
  1. does anyone have a charging wiring diagram? it would be very helpful
  2. I believe you are right. This 2010 legacy has the 2 wire circuit, and I believe the new alternator is not charging. I will have it tested and let you know.
  3. I grounded the blk/wht wire, indicator charge light came on. After swapping the wires, the light still does not come and charging indicates 12.2v. Any suggestions? New alt, new pigtail, battery is charged.
  4. Thank you both, I am going out to try these suggestions. I will let you know, thanks.
  5. 2010 legacy 2.5, rats chewed alternator plug, temp fixed months ago, alt charging @ 15.5, battery light constantly on, a week or so ago light went out, car died sometime later. I just replaced alt w/maniacelecmotors after market, also the pigtail. Now I do not show alt charging. I read the battery indicator light has to work for charging. I need to remove panel to change bulb, I assume. Can anyone advise me how to do this and am I correct? How is the panel removed and can this be done by a shade tree?
