Shawnk
  1. Just purchased a USED 4w, 5sp, dual range for $350 & $150 shipping. Try out WWW.car-parts.com, they will connect you with all the Yards in USA/Canada.
  2. Try to isolate the problem. Jump the solonoid directly. Make sure the car is in Park or netrual (if Stick). I use test kit from my local auto parts store. It has a momentary switch with two alligator clipped wires. the instructions came with the kit. Also try to hook up a volt meter across the battery. If you have 12+ volts when you first hook up the battery then loose it after you try the starter you have arked one of the battery feeds and it has become electricaly detached. Use the Volt meter to check all connections and clean them and retighten. I had a bad ground connection that would carry enough juice for the Headlights but when I cranked it the starter it failed.
  3. Need some help, Engines i can rebuild. this is my first attempt at a transmission. Was in wreck and knocked front Pass wheel hard. front wheels will not engage, but can drive car by shifting to 4-wheel to bring on back wheels. How hard is it to crack case and rebuild. I already dropped trans out of car.
