1996 outback no start
notruck replied to notruck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs it just a pop in? with all the wires and other connects?
notruck replied to notruck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI can see the belt turning. When trying to start. This is 2.5 and I was driving going about 50mph at the time. So I'm thinking the valves are damaged. Because the belt is turning! Is this what you guys think? Thanks Much Dave
notruck replied to notruck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell I pulled the first plug out and did the test...And no compression guess the engine is gone!!! Guys is it worth the time to do a rebuild? It had 235000 on it.. Thanks for your time Dave.
notruck replied to notruck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo I need a specific compression tester for this? and what should the compression be? Thanks
notruck replied to notruck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwould pulling up the codes help at all?
notruck replied to notruck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks would it easy er to pull the front of the engine apart and pull the covers to the belt? I did put a new belt on last year with new pulleys and water pump. Thanks
notruck replied to notruck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have not pulled the front covers off. But I can see the belt turning.
my 1996 outback will not start. As I was driving yesterday it quit running. Im getting gas (pulled the gas line off and cranked it over gas came out. I also sprayed some starting fluid in the intake. I have spark @ the coil.. It turns over good no back fire. any help 235000 miles on it I changed the timing belt last year and I can see that its turning..
notruck
