ltdenisco
Posts posted by ltdenisco
I have 2006 Outback Limited, when making tight slow turns I can feel the torque bind. If I back out of my driveway with the wheel turned and then shift into drive it hits in hard. When the car is in park and I turn off the ignition it will slightly lurch forward.
I have measured all the tires and all are the same, although I did drive the car on a low tire for about 40 miles the day I bought it. it was at about 20PSI
I have checked the voltage to the transfer clutch duty solonoid 1.5 to 1.8 Volts with the solonoid connected, key on, 1st gear, not running.
I have checked the voltage at the solonoid with the AWD Fuse in, 0 volts at the solonoid. The car still binds with the AWD use IN. I have checked the trans temp sensor, 4000 ohm at 70 degrees F.
I have checked the throttle position sensor , (OK)
I have changed the fluid twice. one flush and one filter and drop with subaru ATF.
I think the transfer duty solenoid is under the trans pan on this unit and not in the tailshaft area. Please confirm.
Not sure where to go from here, anything else I could check?
Any help would be appreciated.
Thanks
Chris
Ive been lurking on this site or awile, Love it, awsome info.
Thanks everyone.
Chris
06 Outback Torque bind with fuse IN?
Posted
This is a 4spd automatic. Has 120,000 miles on it
Thanks
