tripletech263
Everything posted by tripletech263
  1. i finally found the injector connectors from deatsch werks, but i need the coolant temp sensor (not sender) connector. those were the main ones i needed, but haven't gone through all my engine bay so there will more than likely be more i will need. thank you for all the info so far!
  2. i have a 91 subaru legacy turbo..i have several broken connectors and hacked wiring on my engine harness from prior owner. i cannot source these connectors and cannot find a harness on ebay. i have found a harness for a 99 impreza outback with a 2.2 mt. will the connectors for that work on my motor? i can solder and fix most of my current harness but can't fix the broken connectors so was hoping to source them from another harness.
  3. that would seem a little more plausible than the valve covers, but the valve covers need done regardless. when i'm installing those i will check both of those as well. again thanks for all the suggestions!
  4. i am picking up some valve cover gaskets tonight, they definetly need done. when i originally looked at it, it seemed as though the plug tubes were higher than the valve cover gasket area and wouldn't drain into them if they were leaking. i just wanted to make sure there wasn't anything else major that someone else had run into with this. thanks for the advice!
  5. new here, looking for some help. i have a 1991 subaru legacy sport. was replacing plugs in it and the front most passenger side spark plug hole was half full with oil. the car has been having a hesitation around 2500 rpm. i have seen the threads about the plug tube seals going out on the 2.5 motors but these don't appear to have the same set up and have not been able to find any seals at any parts stores or fiches. any help would be appriciated!
