d-hunter1
  1. 1-3-2- 4, The white piece that is round is a Nylon washer that goes on your tank bolt on the inside. I just dissasembled mine and it's worn at an angle. I will replace that along with the 2 o rings that are between the reservoir and the pump. One ring part 34427AA060 I got from the dealer. But there is another oring on mine that is larger and in the grove on top of the pump that several people have commented on above. Apparently some don't have that oring. Bearbalu has a good picture of the second oring on the pump itself. The smaller one actually mounts on the reservoir where it goes inside the pump.
  2. Not nessasarily Nipper. Sorry but if the spedo is still working it may just be as simple as loose screws behind the cluster.
