andruski2_suby
Posts posted by andruski2_suby
also do you have any pictures of of them right now
I'm interested in the adapters let me know what you looking to get out of them I live in Portland Oregon so you might have to ship them
I'm just curious if you're still making these adapters and where can I get them
well there's been some interest in my adapters, so im starting a vendor thread.
heres the prototype: I have about 5000km on these, no problems yet.
Stock material is 6061 T6 aluminum. standard material for all internet wheel spacers.
MOUNTING INFO
- the 4x140 pattern is tapped with a M12 x 1.5 thread to facilitate bolting through the original stud holes to the hub. i will supply M12 x 30mm class 10.9 mounting bolts. you need to knock out your studs and put the bolts in their place, torque is 72 ft-lbs, blue locktite MANDATORY! retorque after 100kms.
- Note how the bolt sticks thru a TINY bit on the above pic. This needs to be touched with an angle grinder or just filed off. I wanted max thread engagement, so you have to live with this.
STUD INFO - DORMAN 610-320 is recommended
- the 5 x 100 pattern is drilled for an M12 1.25 stud with a 12.8mm knurl. the stud head size that i used was 19mm dia, by 4.5mm deep. check your stud head diameter and thickness before installing. you may need to grind them a bit. these holes are a PRESS FIT. i had to put about 1000psi on mine to get them seated, but you really don't want them to spin, so tight is good. Length of studs needed is M12 x 40mm long. Nissan pathfinder studs are M12 1.25 x 41.5mm - they should be close enough, you make the call. I am not providing studs.
- When pressing - make sure the receiving die under the adapter is as small as possible, while still clearing the stud threads. A bit of oil is ok. Freezing the studs overnight may help too, but dont heat gun the adapter you may wreck the temper.
CENTER BORE
its 1.98 inches. you may have to grind your 36mm socket. mine fits.
RIM CENTERING
these provide a 7/8 offset, with a 3.5mm tall lip to center the rim on.
price will be 60$ a piece. for one adapter and 4 mounting bolts
thanks soobydoo, capn_r , 86BRATMAN, and bratman18 for the initial interest here: http://www.ultimatesubaru.org/forum/topic/137844-matts-gl-sedan/
edit note - i am filling in the necessary finalized details in bold , as i nail it all down.
A while back I read up on a guy here in the forum That was manufacturing spacers 4 older Subarus with bolt pattern 4x140 to 5x100, I'm just curious if anybody knows of him Or if hes still making them..
Hey I'm just curious where can i buy the stripping spray used for stripping The clear coat? I just bought a pair of rimd for my 88 gl-10 wagon they're in pretty bad shape
mechanic in Vancouver/portland
Posted
503-936-7503 call these guys they did my head gaskets On 03 legacy for under $900 tell them that andrew senT you. they have a small shop in Northeast Portland but they specialize in Subarus
