Everything posted by seth3030
Hitachi?
i have a carter weber and want to convert to a hitachi. how and where do i get the conversion kit and what else am i going to need to do?
weber carb q's
i have already done that and it did nothing.
weber carb q's
My weber is running real crappy and i was wondering where i could get a new/ rebuilt one on the net for a reasonable price? or how would i put a hitachi on there?
i need a diagram or some help
so i need to hook up three wires to the fuse box? thanks for the help
i want to put a cd player in my 1982 gl wagon and i need to know how to do it or what i need to change to make it work. anything would be help full
clutch pedal/cable
i just found that where my cable attaches to my pedal right by there there is a retaining clamp, on a metal peice the metal peice is ripped and i don't know what to do so if anyone could help that would be great.
engine won't turn HELP!!!
so how do i figure out which lead goes to which side one is black and one is yellow.
clutch replacement
We are doing our first clutch job on an 84 subie 4wd wagon. Everything has gone fine so far. We are now getting ready to put the motor back in but we don't know which way the clutch goes on. Any suggestions?
Clutch!
thanks man!
Clutch!
my clutch pedal is way lower than my brake pedal so how do i adjest that and could that also be why my clutch is slipping so much? i have an 82 wagon if that helps. thanks
How do you adjust the clutch cable?
How do you adjust the clutch cable? i have an 82 subaru wagon 4wd
Best way to replace clutch
Should i replace my clutch by moving the engine forward or dropping the tranny and if you have a preferance tell me how to do it that way. thanks for taking the time to read this any help would be appreciated!
weird noise
yeah i looked at mine and they are fine.
weird noise
theres a grinding noise from the front drivers side axel. when i am driving strait and at a constant speed it grinds but not when i am turning or accelerating it stops. and i have checked the cv joint and its good so i don't know what it is. it's like scrapeing but it is not constant it scrapes then it stops so the faster i go the faster the scrapeing is. sorry if thats really f****** confusing.
where is my switch box?
no not the fuse box cause i am looking at the diagram and it shows the wire with and arrow to "switch box" not to the fuse box thats why i am confused.
i have a 82 wagon and i don't know where my switch box is. cause the guy that had my car before me messed the wireing on the radio and one wire is supposed to goto the switch box. so any help would be appreciated thanks.
could i wire and i pod to work in my car?
i was wondering if i could hook my ipod up to my speakers some how? cause my radio wireing is all messed up and i think that hooking up and ipod might be easier.
Where to find weber carbs?
does anyone know where i can find new/ rebuilt a single barrel weber carb?
please help me with my cv joint
how do i replace my rear cv joint on the drivers side? i just got it out of the rear diff now how do i get it out of the rear drum break, do i hit the pin out just like on the rear diff side?
carb switch
where would i go about getting a redline adapter plate? and does that just make it so it fits without having to get the whole intake manifold? also would i need a new computer for the carb?
how to rewire an 82 for a cd player
does anyone know how to rewire an 82 wagon for a cd player, it would be a big help thanks.
carb switch
i have a single barrel carber weber card and i want to switch that to the hitachi carb i have a 1982 gl wagon 1800. so what do i need to do? my brother says i need a new intake manifold.
