92legacy_wagon
  1. Thanks. I hoped it to be a relay too all the fuses were good. We'll see what the meter says and hopefully I can track this down.
  2. Yep, checked that. If I'm not mistaken that also controls the dash lights?
  3. ahhh bloody hell, I thought someone might say that. Don't have a meter but will borrow a friends and see what I can find. Just figured there was THAT switch I could have replaced. Thanks.
  4. I have a 92 legacy wagon and the tail lights aren't working. In fact, none of the running lights work. Even further, the left side front turn signal is out and even when I changed the bulb, the other was bad, it didn't work. The switch above the steering column won't turn anything on. I DO have brake lights and my dash lights up. I have checked all the basics, fuses, relay, bulbs and still nothing. What else can I check? For what its worth, I have always left the running lights on. I also swapped out the rear hatch but the other musta been from a earlier/later model cause not all the wires matched. I don't have a rear defrost and the lock doesn't work which I don't care about, just the tail lights but I thought I'd mention it anyways. I did check my connections there and everything looked fine. Thanks for any help.
