tvik
Posts posted by tvik
My 01 outback kept dying yesterday. I was driving and the car jolted and tach instantly dropped to 0 rim. I cranked it over and it would not turn over. I wait a bit and it starts. I changed the fuel pump relay and fuel pump and it stays constant at idle but when I put it in gear it'll die at random times the same way. It jolts like when you drop the clutch and the car lunges then turns off. I need help with any ideas. Tested the fuel pump after installing it when it was priming and it was 12 volts. So I know the pump is working.
I'm lost. Any ideas?
I have a 01 outback Wagon I am turboing and need help on location of recommended location of oil feed and return lines to engine block
1998 impreza outback engine swap 2.5 turbo
in Turbo Engine Tech ('91 and newer)
Posted
I have a 01 outback and going to put a ecu and engine from a 98 legacy forester. My outback is a 2.5 sohc and the new one will be 2.0 dohc will the ecu's match up harness wise or do I have to repin the new one?
