stevejoy5
  1. Hi people, i wonder if any of you can help me???? i have a 93 wrx and it has got a problem with the boost!!! i took it to main dealer and they put it on the computer which found no faults, i then took it to a sports place and they found a restictor in a pipe which went from the boost sensor(i think) its mounted on the suspension strut, when the restrictor was taken out it boosted to 16psi but now it overboosts or it underboosts. anyway changed the boost sensor and it was no different am running out of ideas what it could be need some help..
  2. I have a 92/93 wrx imprezza import and am trying to wire up a rear foglight switch as it does not come with one, does anybody have a wiring diagram??? please.. if not any ideas
  3. its a wrx 1992 the problem exists threw out every gear the car is an import, i have had the coil packs changed, a regular full service. i am not sure what else i can tell you
  4. my impreza is playing up most of the time it boosts to 14psi but occasionally it will only boost to 8psi has anyone any ideas cause it is annoying?
