andrewbutler777
  1. I am trying to diagnose my overheating issue with my wagon. I am trying to find out if there is a good way to tell what the problem is? First I found a busted hose by the water pump, replaced it, it ran for a day without issue. Then it came back. Then I did the thermostat replacement. Then I found a small leak in a metal coolant line (near throttle) patched it with JB weld. I thought that would fix the issue. No deals. I am trying to figure out the next step to find the problem. Is it the water pump, radiator, head gasket? Something else. It does not blow white smoke. The water pump does not make noise. It does smoke a little under the hood near the throttle area. Could it be that it is not circulating oil properly? Could that be it? Any ideas on how to definitively find the problem will be very helpful. Block test next???? Thanks all.
