Farewelltoernest
Everything posted by Farewelltoernest
  1. Thank you guys so much for replying! I suppose I'd better get that alternator bracket back on stat. Any idea if that's what is causing my battery light issue? Probably not, but worth asking. From what I can tell the studs on the block are just as they were before dropping the exhaust. EGR pipe is connected, yes. O2 wires came out of the plug, not the sensor itself. Just need to know the order to plug 'em back in. The valve shims were not changed or removed. Buckets were labeled before removing, and out back in the heads in order. The car has a lot of miles, and made the sound before, it was just MUCH quieter than it is now. Same thermostat. Weird thing- I unplugged the out of order wires from the o2 plug- and it's no longer acting erratically. I am still planning to remove the air from the cooling system though. Car never overheated with the old HG's. Just some minor fluid mix. I'll bump the thread when I change out exhaust gaskets and let you guys know how it went. I also want to take a look at the intake and see if it's the same story there.
  2. Hey everyone, I also posted this on the forester forums, just need as much advice as I can get. I respect ya'll a ton. Happy 4th of July guys! I am in dire need of some diagnosis for this poor trooper 98 DOHC M/T Forester (236,000) I'm going to start by telling you that I'm pretty sure these problems are my fault, and not something that would naturally happen to the car over time. She also wants to go- and fast. No resistance or hesitating when accelerating. If these problems weren't here, this Subie would be a dream. I've just completed my first head gasket replacement. It was hellish, and I was foolish to think it would all work out great.. So I'm just going to list the symptoms and hopefully we can narrow it down from there. All advice appreciated. 1. She sounds like a diesel. Not like a TDI Volkswagon, but like a rig. It's louder on the Drivers side. There is an exhaust leak at the manifold right now- It smells awful and the smoke comes out of both sides. Like an idiot I used RTV on the block side of the gaskets, which were rather flimsy non OEM gaskets to begin with. My plan is to replace them with OEM's, but I don't know if that is the cause of the loudness. Intake manifold leak? Here are some vids: 2. O2 Sensor wires/Mystery Sensor So while I was removing the nuts for the exhaust manifold, I was expecting some sort of center exhaust support to back me up- instead the whole thing dropped. It ripped out 3 wires out of the front o2 sensor and I have no idea where to put them in the 3 wire terminal. There's one black wire with a gold blade, and 2 white ones with silver blade. Also, you'll notice a small, gray sensor plug in the 2nd photo in front of the o2 sensor terminal. Where does it go? It has no slack and I can't find anything to plug it into near the big bracket. 3. Overheating According to the temperature gauge (which is acting bizarre anyway) She gets hot rather quickly. If leaking coolant at all, only in small drips coming from the lower radiator hose. Rear drivers side hoses connected and clamped. Filled up with fresh, clean coolant. Overflow tank is full. Car has plenty of new 10w-30 in it. Full on the dipstick. I don't understand it. 4. Electrical issues So in the final stages of putting the car back together, I managed to snap the bolt of the positive terminal on a 1 year old Bosch alternator.. and only had enough money to replace it with a frickin' duralast. The battery light is on on the gauge cluster. But then again, so is the brake light (it doesn't turn off now, the reservoir is full of dot3), and the temp gauge occasionally goes nuts, as in, at the bottom while stopped at a light, and a hair away from the red while driving, and then in the middle, and then at the bottom again. I am going to have the duralast (rebuilt in mexico and "tripple tested for quality assurance") alternator tested, but due to the other issues I feel like it might be an issue with the ground cable. Is it in the right place? Here is a picture of it (in between starter and bolt head, not starter and block.) 5. Mystery pieces Anybody know where these go and if they are important?? I love this car to death you guys. I want it to live a long and happy life. Please help me out here.
