Everything posted by G14 James
79 transmission input shaft seal.....WFT
thnaks, Guy at NAPA told me same thing, guess it just a moremodern seal VS 30 year old seal. just wanted to be sure since its a lot of work if it leakes
The seal with the meatla ring is the original seal NOK AE1032F and the other is suppose to be the replcement Timken 222050. It is quit obvios the its not the correct seal. Does anyone know the right part number for this seal? and where to get it? Any help is appriciated since i cant put the transmission back together till i find a new one.
Need rebuild maunal for 79 Brat Manual trany
Well its apart so now i need to known what position things need to be in when it goes back together. Its pretty simple but im sure there is a right and wrong way to do it
BOSS Gen 1 BRAT/4wd lift kit Christmas Deal
sjrlift.com
OEM window molding
i have the same problem with the seals and finding a sutible replacement, i was considering walking around a salvage yard till i find somthing close.
Voltage regulator 79 brat
so i have put in a new alternator, new battery, new battery cables and purchased a new voltage regulator, after it was installed it seem fine until the vehicle is started at which point it begins to smoke. I put the old one back on and it works fine. is there a way to test them to see if the old one has already burt out what the new one seems to be working on burnin out. Or could they have given me the wrong one. The connectors are all the same just the internal look a little different but i thought maybe that would be just upadted.
Starting the journey to find a Brat.
i Live in Florida, found mine (1979 Brat) on criagslist in Arizona for $1000 and it runs and drives, cost me about $800 to ship it from there to FL
radiator replacement?
im going to assume that there are no oem replacment radiators avialable anymore for the first gen , if the are where. Has anyone found another radiator that is a good replacement. The one i have is repairable but might be a better idia to just find another that wil fit.
1979 brat parts
i have a 79, heard the slack is normal. Mine has alot. not sure on body panels
1979 Subaru Brat...My questions and add yours if you like
well somone stole the winch then . Thanks
Thats the odd part the vehicle has a EA71 in it and its stamped clear as day. This is an extra motor that was thrown in with the deal
yeah the voltage reg is on the other side. looks like a relay of some sort and seems to have no use since the engine runs and everything seems to work
I think ill be adding many questions as this goes along and figured i would just consolidate them all in one place. I will start with somthing easy i think. what is this( see pink arrow in picture) and what does it do? there are no wiires attached to it so i dont have a clue
1979 Brat Headlight or headlights?
i have the grill, guy i got it from gave me three extra and one was the 4 headlight, i would just need the buckets and brackets but havnt decided which looks better
sweet thanks i might try swithching to four since it came with a GL grill but might look funny with the cutout under the light. Would it matter if i had the wrong plug attached to the light?
i purchased a 79 Brat about a month ago and im a little confused on the healights. It has the two headlight grill and they work on low beam but not high beam. What is strange is that there is four headlight plugs but only two healights. are these the wrong headlights. the grill seems stock since it matches the the headlight cutout in the body below it and the four headlight design is stright across.
1979 Subaru Brat......my new project
