jabarrow
Everything posted by jabarrow
  1. Hi, I am looking for a 5-spd manual trans for my 2003 2.5L Outback wagon. Do I have to get one from another 2003, or can I use one from different model years as well? Or can I use one from something other than an Outback wagon? Will one from a sedan work? Thanks james
  2. Hi all, I bought my outback at 125k miles, and pretty much immediately did a major suspension overhaul....new bearings on all 4 wheels, new CVs on all 4, ball joints, tie rod ends, etc, etc, etc. It's now at 157k. It is the 2.5L 4 cylinder with a 5-speed manual tranny. Now it is making a noise that I think I have ID'd as transmission. At first the noise was intermittent, and sounded like a scraping, grinding, bearing sort of noise, which was not really all that loud, but still very noticeable as "something going wrong". Now it is pretty much constant and has changed into a soft whirring sound that is weirdly similar to crickets at night. Not very loud, just barely noticeable above all the rest of the noise the car makes. The noise definitely comes from the front end of the car, but sounds the same from either left or right side, which I am assuming means that it is coming from the center, left to right. The noise occurs when the car is moving, and seems to be independent of anything other than speed. It does not matter what gear, clutch in or out, whatever. The only significant variation is that once the car gets really warmed up good, the sound is a little louder. I checked out all the obvious stuff....wheel bearings, CVs, etc. No obvious problems. I took it to my local mechanic, he found no obvious problems. So, I'm thinking transmission, maybe the rear output shaft bearing? So my question is, Before I go swapping trannies, is there anything else the noise could be, or does my diagnosis sound right? Thanks a lot james
