Everything posted by LeftHandRev
2001 Impreza Wagon - Fog Lamp Wiring
LeftHandRev replied to LeftHandRev's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCorrect. Just an empty pink socket above the fuses. This car didn't come with the fogs from the factory. I got all the parts from a 99 Imreza Outback. I just didn't realize I was missing stuff like the relay. I'm trying to find the bezels now, which I can be patient on.
LeftHandRev replied to LeftHandRev's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX[deleted]
LeftHandRev replied to LeftHandRev's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlright, here we go. Fairtax steered me well, I got everything wired up and and working. Here's a link to the photos. Since I'm using my phone, I'm just going post the imgur link.http://imgur.com/a/cQejF
LeftHandRev replied to LeftHandRev's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe have success. Post images later.
LeftHandRev replied to LeftHandRev's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh, I understand. I didn't see the relay nor did I hear the click, perhaps it's not there due to this being an L model. I'll see if I can locate where it should be and find a relay either at a store here in the city or online. This looks like my setup - I am certain that relay is not there. I'll attempt to find one at the autoparts store in a bit and report back. I bet dollars to donuts that fixes everything.
LeftHandRev replied to LeftHandRev's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThank you for the replies. Helpful so far, but I haven't solved the problem. First, I tested the switch itself. I got 12v of power to the switch. I tested the switch's integrity and it was also fine. Next, I checked the integrity of the ground wire at the fog lamp with the meter by touching one tip to the negative and the other to the body - again, ground was ok. At the same time, I checked the postive terminal for voltage, again - same as last time - no power. Third, I pulled the fuse out and cleaned the blades. Popped it back in, no joy. I put a brand new fuse in, also negative results. It seems that somewhere between the switch and the wiring harness hookup there's a loss of integrity. unforunately, I don't have enough slack on the multimeter to check circuit integrity back to the switch. Hopefully someone has another suggestion for me. I'm going to start looking at wiring diagrams next. Thanks for the help so far! It's much appreciated.
Hi all, This is my first post. I did a few searches, but didn't find exactly what I was looking for, so I thought I'd ask. I picked up some fog lamps from a junkyard off of a 2001 Impreza Outback. My Impreza L Wagon seems to be prewired for the fog lamps, and had both the point under the bonnet to attach the lamps, as well as for the on/off switch inside the cabin. There was a fuse marked "fog" (not blown). I put everything on the wiring and hit the switch, but didn't get any light. My next step is to take a multimeter down and verify that I've got power to the harness. I am curious though, has anybody else done this successfully? Any pointers? Thanks! lhr.
